guages question, please help
Old Aug 26, 2009 | 07:03 PM
Bergen Automotive's Avatar
i have a ix mr, so it comes with those 3 guages, if i were to do a double din and want to relocate my guages to the pillar and put the ac controls on the bottom, after i buy new guages can i use the same sensor and wires going to the OEM gauges to run the new gauges? or will i have to redo everything all over again?, thanks
Old Aug 26, 2009 | 09:51 PM
chaotichoax's Avatar
you can make use of the tubing for the boost gauge
the oil pressure sensor is of no use to you
and I would swap out the volt meter gauge for a wideband o2 gauge or an oil temp gauge
