New at the EVO thing but have a question
Old Aug 24, 2009 | 01:43 PM
KenRed's Avatar
I know there's threads already about my question, but I did search LOL. I'm looking to get either a 05 non SSL with HID's or a 06 IX. Now i know the differences between the two (motor wise) would be the mivec system, and the larger turbo, but if I got the 05 and did the AMS motor swap (later on down the road) the mivec advantage wouldn't make a difference right if I was to run a 06 with the same mods on the drag strip?
Old Aug 24, 2009 | 01:53 PM
markymark1082's Avatar
Not really sure what you are asking. Yes MIVEC makes a difference.
Old Aug 24, 2009 | 02:04 PM
F1fan07's Avatar
This is a confusing question.
If you are going to swap the motor/ turbo then it doesn't matter, and actually the 05's have the same turbo as the IX's, if I'm not mistaken, so you are only down the MIVEC.
If you were going to keep the stock motor and turbo setup, then the MIVEC would make a difference. If you are going to swap things then no, it won't matter.
Old Aug 24, 2009 | 02:07 PM
tim85851's Avatar
the 05 VIII's turbo has the same hotside as the 06 IX's turbo (10.5)
the compressor side is different...
if you get an VIII and get a built motor its still gonna be an VIII built motor without mivec.
if you get a IX and get a built motor its gonna have mivec...theres too much to swap if you want mivec in an VIII...
hope this helps?...
Old Aug 24, 2009 | 03:18 PM
EclipseMblue's Avatar
Swapping a mivec motor into a 8 is pointless and probable very costly. its like spending 3g's on a turbo kit for a neon just to get 30hp more out of ur car its not worth it. just buy a 9 and build the mivec
Old Aug 25, 2009 | 04:17 PM
Boostin4life's Avatar
Lol on the neon comment... I still own an 05 for the moment, should be sold this week then it's on to evo. My kit was only $1800 and made 471hp..... But back to topic, How much differance does mivec really make?
Old Aug 25, 2009 | 04:25 PM
wtbEVO9's Avatar
depends what your plans are for the car...if you plan on going with a bigger turbo down the road, mivec will work against you. MIVEC head flows well and is definitely an advantage for stock framed turbos(FP Green, FP Red, CBRD BBK, Tomei Arms, etc..) mivec head is also much more costly to maintain and spark plugs alone can run you over 50$. I wouldnt suggest switching an evo 8 head to an evo 9. All the big HP evos around here all run evo 8 heads.
Old Aug 25, 2009 | 04:40 PM
R0b's Avatar
R0b
^+1 to that.
as others have mentioned, it comes down to what are your plans later on
moderately modified or the full race thing.
Old Aug 25, 2009 | 04:52 PM
EvoDom's Avatar
no point in swapping to mivec in an VIII waste of money
Old Aug 25, 2009 | 05:21 PM
adammartini's Avatar
ya just get the ix, i would have if i could afford it
Old Aug 25, 2009 | 05:33 PM
TommiM's Avatar
Both can make good power. I think a good tuner can help you max out either setups. How much power do you plan on making?
Old Aug 25, 2009 | 05:41 PM
Not sure if ur asking me or the one that started the thread lol..... I'm gona shoot for 450hp+
Old Aug 26, 2009 | 07:58 AM
TommiM's Avatar
sorry. askin the OP. Its easier, yes, to get 450 hp out of the mivec, but its not terribly hard to get out of the VIII 4G63 either. I mean, unless your trying to squeeze out the aboslute last hp for some dyno number, it shouldnt matter that much.
Old Aug 26, 2009 | 10:21 PM
Void21's Avatar
What kind of spark plugs are you buying? Mine are like $7.
evodomUA
Nov 20, 2020 02:30 AM
EVOlutionary
Oct 15, 2017 04:11 PM
enthuziast
Lancer Engine Tech
Jun 1, 2016 08:04 PM
06mr775
Sep 30, 2015 02:33 PM
EVOIX4me
Aug 1, 2006 07:51 AM
