Boost gauge people, how much vac do you see at idle?
I installed my boost gauge yesterday and my boost readings seem to be fine. Spikes/holds 18 psi in the midrange and slowly falls to 16 psi by 7k rpms or so.
However, I only see about 14 in if Hg at idle where I'm used to seeing 20 or so in other cars consistently. Is this correct or do I have a vac leak somewhere? On decel, I can get it as slow as ~19-20 in/Hg.
Normally .20 but somtimes depending on the weather it will idle at .15-.17 . I think you are fine just get a boost controller and crank up the powaaaa
But ya you are ok I doubt there is a leak.
Originally posted by WannaRace
14 at idle..I think we have the same boost gauge
My vac signal is the soft vac line on top of the valve cover that feeds the diverter valve.
Re: Boost gauge people, how much vac do you see at idle?
What does 19-20 in/Hg mean? And what levels should you expect to see idling, accelerating, shifting, then say standard highway driving? What would the gauge do if you were experiencing leakage?
-Thanks
Idle: 17-18 Hg
Decel: 20-21 Hg
dividedsky: When driving I am hardly ever in positive boost unless I am excelerating.....on the highway mostly around 5Hg to 2psi depending on landscape. If there was a leak in your boost lines, trust me, you would know it
Decel: 20-21 Hg
cause of my cams
