Boost gauge people, how much vac do you see at idle?
Old Feb 7, 2004 | 03:59 PM
jbrennen's Avatar
From the Evo's shop manual:
MANIFOLD VACUUM CHECK
1. Before inspection, check that the engine oil, starter and
battery are normal. Also, set the vehicle to the following
conditions:
•Engine coolant temperature: 80 −95C (176 −203F)
•Lights, and all accessories: OFF
•Transaxle: Neutral
2. Connect an engine tachometer.
3. Attach a tee-fitting joint to the vacuum hose between the fuel
pressure solenoid and the intake manifold plenum, and
connect a vacuum gauge.
4. Start the engine and check that idle speed is within
specification. Then check the vacuum gauge reading.
Idle speed: 850 ± 100 r/min
Minimum limit: 51 kPa (15 in Hg)
So at idle, you should see vacuum of at least 51 kPa or 15 in Hg, which is about 0.5 bar.
Old Feb 7, 2004 | 06:30 PM
Invoice EVO's Avatar
Veteran: Air Force
17-18
Old Feb 9, 2004 | 03:20 PM
mjones53's Avatar
Old Feb 13, 2004 | 10:19 AM
nonmature's Avatar
ok ok I idle at 20 which is much like a lot of us... but when I slam on it I spike above 20 and it drops down right above 20...
I dont think thats right ...Is it??? all I have is a BR turboback and an HKS RS kit
-non
Old Aug 26, 2009 | 08:03 PM
brenner's Avatar
but if you are cammed, its normal to see less than 15 correct? i see around 13-15 at idle, 19-21 on decel. GSC S1 cams.
bren
Old Aug 26, 2009 | 08:29 PM
MitsuJDM's Avatar
bren
Yes, lower vaccum with cams is totally normal. My Comp 280's are at 10-12 in-HG.
Old Aug 26, 2009 | 08:45 PM
abdizzle's Avatar
So a Idle vacuum that appears to be within spec (17-20 on stock Cam's) would indicate that there are no leaks correct? Or is it possible for leaks to still exist even when my cars shows 20 at idle?
Old Aug 26, 2009 | 09:28 PM
AznEvoIX's Avatar
Mine is usually somewhere between 18-20 depending on how and where I decelerate.
Old Aug 27, 2009 | 07:29 AM
Aven's Avatar
20 at idle , 18 with the AC on.
Kyruuu
Oct 29, 2015 01:44 AM
ImsoevoX
Evo X How Tos / Installations
37
Apr 26, 2013 12:28 PM
CrawlinTBSS
12
Sep 29, 2011 05:42 PM
Ltdanish07
May 25, 2011 09:23 AM
Mitsu.kid.02
Lancer Aftermarket Forced Induction Tech
Oct 28, 2010 09:00 AM
