passenger tail light not working
Old Aug 27, 2009 | 06:23 PM
shawn360h's Avatar
Yesterday i relized my parking lights on my passenger side were out. My brake lights and reverse lights worked fine. I changed both bulbs today because they were both blown. They still didn't work so i checked the fuse and it was also blown. I changed that and it worked. Later i went for a 10 min drive and come home to the parking lights being out again. I tried to put in a new fuse in and it immediately popped. The bulbs in the tail lights were not blown tho and i then noticed the parking light in my headlight was also not on. At this point i came to the conclusing i have a dead short. I had a body shop install jdm headlights about 6 months ago while i had so body work done. My question is could it be that the body shop messed up and theres a worn through wire somewhere? Is the front marker light on the same fuse as the tail lights or that on the low beam headlight circuit? Any help would be appreciated i would like to resolve this quickly so i don't get a ticket
Old Aug 27, 2009 | 06:26 PM
Evoryder's Avatar
check ALL related fuses, one is out causing the problem.
Old Aug 27, 2009 | 09:52 PM
krayzeviet's Avatar
i'm having the EXACT same problem.... it's blowing the passenger rear taillight fuse along with the third brake light bulb
Old Aug 27, 2009 | 10:09 PM
AznEvoIX's Avatar
Fuse.
Old Aug 27, 2009 | 10:11 PM
C_LosEvo's Avatar
check your connections. i had the same problem and i found out that my cigarette lighter cable was tangle and striped with my shifter and was causing a short.
Old Aug 28, 2009 | 04:36 AM
shawn360h's Avatar
I checked all the fuses under the hood and they are all good except for #20 which is the passenger tail. Is the front marker light on the same circuit or is it on the headlight ciruit?
Old Aug 28, 2009 | 02:24 PM
shawn360h's Avatar
What other accessories are on that circuit?
Old Aug 28, 2009 | 03:15 PM
Routybouty's Avatar
If your blowing fuses, putting another fuse in will not fix the problem.
I would check the tail light assembly connector itself and surrounding wiring for shorts. Also check the bulb connectors for deformation.
Old Aug 29, 2009 | 06:26 AM
shawn360h's Avatar
I know the problem doesn't have to do with the tail light or head lights because i would disconnect them and it would still blow the fuse immediately
Old Apr 11, 2011 | 05:55 PM
evolove718's Avatar
So what is the best way to fix this problem because im having the same problem to the passenger tail light doesnt work not even if i put the brakes on now. The driver side works fine. Should i check all the wiring and change the fuse or ...?
Old Nov 15, 2013 | 10:08 PM
blackoutVIII's Avatar
Updates?
Old Nov 17, 2013 | 01:51 PM
I fixed mine yesterday and found it was a loose and exposed ground cable behind my stereo. I covered it with electrical tape and re-tightened it. I also cleaned my battery terminal, since it was making a buzzing sound and had a lot of green build-up. Everything working properly.
Old Oct 25, 2016 | 01:13 AM
2rbolag's Avatar
Are both the brake light & parking light (inner & outer) bulbs the same bulb size? Only my outer lights turn on
Old Oct 25, 2016 | 08:56 AM
krayzeviet's Avatar
I had just installed a new radio when I posted this years ago. I took out the aftermarket radio and found out one the illumination wire from the radio wasn't attached and was touching ground. The wiring diagram showed that the radio and tail light harness were all connected. As soon as i fixed the radio wire it fixed the fuse blowing problem i had to the tail light. Hope this helps.
Old Oct 25, 2016 | 09:37 AM
2rbolag's Avatar
My issue is different, my front parking lights works as should.....my rear parking lights are not. Neither the driver nor passenger bulbs light up. I tried replacing with both halogen and led and no dice. Is there a fuse sorely for these bulbs?
