Need New Ballast?
Old Aug 31, 2009 | 10:10 PM
jahnplay's Avatar
Need New Ballast?
so i took my car to the dealer i bought the car from. have them check on my headlight because it flickers then turns off. so they said its a bad bulb, then they said i need a whole new headlight assembely. which is $600 and they don't want to cover it under the dealers warrenty.
so my question is can i just buy a new ballast? or just a whole new HID kit?
i can get a cheap ballast from here. http://www.vvme.com/hid-replacement-ballast-c-16.html
had 4 kits from them no problems.
Old Aug 31, 2009 | 10:28 PM
LuisIX's Avatar
its the bulb thats going out..just buy some d2s bulbs on ebay or hit up hid planet and score some used ones there.youll be paying about 60 for some used bulbs...
Old Sep 1, 2009 | 02:48 PM
falcontx's Avatar
Best way to diagnose the problem is switch the bulbs from one side to the other. If the problem follows the bulb, then you know the bulb is bad. Or, if the problem remains on the same side, you know it's the ballast.
Once you know the cause of the problem, you can just replace the defective part. There's no reason to purchase an entire new headlamp assembly.
Old Sep 1, 2009 | 03:39 PM
LuisIX's Avatar
if you do that youll blow the bulb and hes ***kd
Old Sep 1, 2009 | 03:56 PM
EvoJoeIX's Avatar
you can buy a whole new HID setup from an aftermarket company way cheaper then the dealer
Old Sep 2, 2009 | 06:42 AM
mexigun's Avatar
I had this same problem a few months ago. My right headlight would flicker and then cut off. The problem was diagnosed and I needed a new control unit for the headlight. Would have been an expensive fix but i have an extended warranty.
Old Sep 2, 2009 | 08:37 PM
jahnplay's Avatar
for some reason it worked when i changed my fogs to HID
LordCthulu
Jun 18, 2015 05:13 PM
robyn402
Oct 18, 2010 08:18 PM
cdupont03
Sep 23, 2008 01:38 PM
justin44
Aug 29, 2008 12:00 AM
gilliam
Feb 14, 2007 10:51 AM
