ate a curb...bad
Old Sep 7, 2009 | 08:32 PM
macPSU's Avatar
Originally Posted by huevosrancheros
HAHAHA welcome to the club son!
POST PICS
lmao, that's a very warm welcome to a club you don't want to be in.
Sadly, I joined about a month ago
Sorry to hear man, post some pics and maybe we can better judge whether or not they can be repaired.
Old Sep 8, 2009 | 01:25 AM
MADBISH's Avatar
Originally Posted by AndyD
No, the regular 6" curbs will do it. Just imagine a 3100+ ibs object abruptly hitting something that will pretty much instantly stop the it. That's A LOT of energy to instantly stop. The wheels, then the control arms, axles, then the chassis absorbs that energy.
I'm sure the drivetrain doesn't like the impact either.
You must have slammed into it pretty hard. I was under the assumption that you just accidentally ran into a curb pretty decent.
Old Sep 14, 2009 | 03:09 PM
ganda199's Avatar
Old Sep 15, 2009 | 07:56 PM
Ryan.Kauz's Avatar
^^^ thats effed up!
Old Sep 15, 2009 | 07:58 PM
Brsox10288's Avatar
Dang man, sorry to hear that..
Old Sep 16, 2009 | 02:46 AM
boostin_20lbs's Avatar
Wow! You must have it that curb pretty good!
Old Sep 17, 2009 | 08:42 AM
Speed_Freak's Avatar
That sucks man. I put a chip in my Advan RS' a month after I got them and almost vomited. I don't even want to know....
Old Sep 17, 2009 | 08:51 AM
skyblas's Avatar
check your CV joint and axle
the vibration most likely is because your CV joint is bend or your swap bar
Old Sep 17, 2009 | 12:10 PM
foxmr's Avatar
wow that sucks... hopefully you didnt hurt the gears in the rack
Old Sep 17, 2009 | 09:57 PM
divine_evo's Avatar
ouch.
Old Sep 17, 2009 | 10:03 PM
str8kor's Avatar
wow sorry to hear that. made my eyes flinch a bit reading your story : (
Old Sep 17, 2009 | 10:07 PM
D-Mon3y69's Avatar
Originally Posted by Green Meanie
if you hit something hard enough to crack stock rims you most likely bent a control arm or tie rod...best thing to do is take to a shop that has someone good at aligning (Like a shop that does corner weight balancing)....if they have a good understanding of suspension they should be able to tell you whats wrong
toke the words from my mouth
Old Sep 18, 2009 | 10:58 AM
92gsxbaltimore's Avatar
about 7 years ago on Christmas morning in a snow storm, while driving like a jackass in my eclipse, I hopped a curb. Ended up having to have the frame pulled to get it straight. cost around 1200, but if i remember correctly, they charge per pull.
Old Sep 18, 2009 | 06:41 PM
AznEvoIX's Avatar
Ouch.
