Annoying Day
Old Sep 28, 2009 | 08:19 PM
RoadSpike's Avatar
Annoying Day
So i nearly make it to work today and the car just dies. I'm thinking of its probably something simple like a fuse or whatever. Nope the fuses are good and the car pulls a p0335 code which means my crank position sensor is toast.
Culprit:
Loose crank bolt allowed the sensor plate to wobble just enough to destroy the sensor, my fault obviously. Next step is obviously replacement and a hefty dose of locktite to fix the loosing bolt issue.
Lesson for all is to tighten up that crank bolt when doing cams.
Old Sep 28, 2009 | 08:23 PM
chaotichoax's Avatar
sorry to hear my man
that is not sweet at all
Old Sep 28, 2009 | 08:34 PM
rolly1818's Avatar
Registered User
yup i pulled hard on those bolts to make sure they were in!
Old Sep 29, 2009 | 02:46 AM
churbo's Avatar
Sucks man. Only thing you can do is learn from your mistake and hope everyone else does too
Old Sep 29, 2009 | 07:12 AM
raginghadron's Avatar
How do you mistake lubed 123 ft*lb? It's probably more like 150 ft*lb on the bolt.
Old Sep 29, 2009 | 08:52 AM
Kracka's Avatar
Same thing happened to my friend's car a few weeks ago.
Old Sep 29, 2009 | 10:07 AM
SpoolinUp's Avatar
Silver Sponsor
Loctite should not be necessary, just proper torque.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Sep 29, 2009 | 10:57 AM
RoadSpike's Avatar
Yeah i went at it with a big breaker bar to tighten it last time. I think there just isn't enough available friction to get that with a hand tool. I'm going after it with an impact wrench this time to make sure its good and tight.
Old Sep 29, 2009 | 11:26 AM
Rxracer's Avatar
I had the crank pulley on my honda come loose twice. ugh its a PITA i know the feeling..
Rob
Old Sep 29, 2009 | 01:13 PM
xpehbam's Avatar
I had one of those happened to me. Did you have a P0300 before it happened?
Old Sep 29, 2009 | 06:15 PM
RedWing03's Avatar
Yay Life!
Old Oct 1, 2009 | 07:24 PM
W_evo8's Avatar
If you torque it properly you'll be alright. You don't want to risk breaking anything with an impact. With locktite it will be a PITA to get that bolt off again they're already a pain without locktite. I torqued mine (no locktite) and haven't had any issues I put cams in over a year ago.
Old Oct 1, 2009 | 07:40 PM
BrilliantEvo's Avatar
thats ****ty dude, hope you get it worked out and back on the road.
Old Oct 1, 2009 | 08:30 PM
RoadSpike's Avatar
It was done yesterday
Medium blue locktite and a good old fashioned impact. I realized i put the crank bolt on wrong, I thought the washer sat on top of the main pulley but it really sits inside of the pulley wedged in between it. I had it sitting on the washers of the pulley which was the main mistake here.
Kinda feel silly now
Old Oct 1, 2009 | 08:36 PM
ah well, live and learn i guess. just dont repeat.
