Help...
Old Sep 29, 2009 | 10:22 PM
ilestjcollector's Avatar
Help...
so i was installing my Injen kit and i think i hit this accidentally.. whats this? what do i need to do?:confus ed:
thanks!
Old Sep 29, 2009 | 10:27 PM
halfnhalfevo's Avatar
i wouldnt drive it full throttle if you have everything hooked up again... that looks like the stock boost controller thingy doodad that controls wastegate position?
stupid dental school. all the usefull life knowledge i've gained is going out the window.
Old Sep 29, 2009 | 10:30 PM
more in focus pictures / not holding the camera upside down to help orient viewer?
Old Sep 29, 2009 | 10:36 PM
M_lizar's Avatar
Looks like the boost solenoid. And yes please take better pics.
Old Sep 29, 2009 | 10:46 PM
EvoHung's Avatar
Yes that is the boost control thingamajiggy. Just replace it or upgrade it. You can actually bypass that whole sensor if you have an aftermarket boost controller. I haven't used mines in years.
Old Sep 29, 2009 | 10:55 PM
can i still use my car or do i need to get a new one right away? thanks!
Old Sep 29, 2009 | 10:56 PM
hks-gst's Avatar
It's a boost solenoid as stated above. A simple way to get rid of it would be MBC.
Old Sep 29, 2009 | 11:06 PM
Can i still drive the car?
Old Sep 29, 2009 | 11:30 PM
M_lizar's Avatar
I think u can but stay off the boost, might want to get a 2nd opinion I could be wrong.
Old Sep 30, 2009 | 12:19 AM
anyone?
Old Sep 30, 2009 | 12:27 AM
buchnerj's Avatar
Don't drive it under high boost at all. Order a cheap MBC, or a good one if you want to stay with that over the electronic, a hallman one is like 90 bucks. Drop the MBC in there and go get a tune to dial in the boost and A/F settings and you will be fine. For sure don't beat it up or drive it aggressively like this though...
Old Sep 30, 2009 | 06:46 AM
Rxracer's Avatar
That is your boost control solenoid. I wouldnt drive the car casue there is nothing to control the boost. your only other option is to run the wastegate line right to a nipple that recieves boost and run off the waste gate spring. it would be driveable. you will be throwing a CEL now becasue of the solenoid.
Old Sep 30, 2009 | 03:12 PM
SICK9's Avatar
Yep, thats the boost control solenoid.
I would not drive it.
Get a new one from the dealer or mitsubishiparts.net or get an mbc like the others said.
To me the risk seems too great to drive it like that.
good luck
Old Oct 1, 2009 | 01:27 PM
thanks guys.. picking up my new oem solenoid!
Old Oct 1, 2009 | 03:17 PM
80210's Avatar
You can also check part outs I ended up getting one there I think for like 5 bucks
