ACD switch bulb?
Old Oct 6, 2009 | 10:13 PM
aguita's Avatar
ACD switch bulb?
Does anyone knows the size of the acd switch bulb? is a small one with a twist lock base ..must be the same as hazard,fog,IC spray
thanks
Old Oct 6, 2009 | 10:14 PM
LancerEVA06's Avatar
thanks
Hm... in my IX its an LED in a very very tiny twist lock base.
Old Oct 6, 2009 | 11:45 PM
aguita's Avatar
thanks for the response..yea is tiny but mine is not led..just a normal one
Old Oct 7, 2009 | 01:02 PM
It's probably going to be a specialty bulb. Cuz I know the dimmer switch and HID switch is not a 74... which is the smallest wedge based bulb at auto parts stores.
Old Feb 4, 2010 | 11:06 PM
timmiii's Avatar
I believe the ACD and the Interior dimmer switch share the same bulb type which is NEO3-R or neo-wedge 3mm led bulb (I chose to replace it with a LED bulb). It worked for me thus far. The Fog light and the head light leveler switch might need a custom install done but shouldn't be all that difficult.
Old Apr 22, 2012 | 07:06 AM
PAHSCT9A's Avatar
So were all the led bulbs you replaced on the acd, and dimmer were 3mm neo wedge base? I pulled those two yesterday to replace and also the fog light and headlight leveler, Three are the same base size look close to 4mm since the last bulb and wedge are smaller. I forget which switch the smaller one came out of. I might just order all in 3mm to be on the safe side from superbrightleds.
Old Apr 30, 2012 | 06:48 PM
llDemonll's Avatar
did you order these ever? looking to change mine as well
Old May 1, 2012 | 08:19 AM
PAHSCT9A's Avatar
Yes I ordered 7(one for each switch, etc-headlight leveler, dimmer, fog, emergency, acd, cigarette lighter, and ashtray)I ordered the regular LED in cool white, and 3mm base. 3mm is a little lose but works, you can order 4mm base but you have to dremel or grind out the hole in the circuit board. There's other colors if you wan to go that route or if you want brighter you can order the high power LED's. I don't think they would make too much of a difference though since the buttons only let so much light through. Almost each switch has 2 sockets for 2 bulbs each but it adding 2 instead of the factories 1 doesn't make it any brighter also. Here's the link for the LED's. Also you need to unwrap the wiring on the LED bulbs and route then through the socket hole so they can contact the metal on the circuit board.
http://www.superbrightleds.com/cgi-b...pecs%2FNEO.htm
Old May 2, 2012 | 03:02 PM
slvrevosd's Avatar
Call the dealer they can give you the correct bulb size.
Old May 3, 2012 | 06:17 PM
PAHSCT9A's Avatar
From my experience with dealerships, they will not know this information for these small socket type lights or will tell you that you have to order the whole switch complete.
sabotaaage
Sep 22, 2022 01:47 PM
ugatalane
Nov 25, 2016 02:54 PM
icyshark
Evo X How Tos / Installations
Dec 27, 2012 06:02 PM
bnr34rb26dett
Dec 17, 2011 03:41 PM
cold_meat101
Dec 16, 2009 02:03 PM
