The New Path
Old Oct 7, 2009 | 01:47 PM
MitsoKid's Avatar
The New Path
I have decided to go a different route with my evo build.. Its gonna be a Time Trial car now.
New parts that should be on the way or I already have:
Engine:
CP 9.5:1 Std Bore Pistons/ Rings/ Pins, ect..
Eagle Rods/ ARP Rod bolts
ARP Headstuds/ Main Bolts
ACL race bearings
HKS Headgasket
Knife Edged, Cross Drilled OE Crank
New OEM Water Pump/ Oil Pump
New OEM Tensioners
Gates Blc Shaft/Timing Belts
JUN 272/272 cams re-ground by GSC Motorsports
GSC Beehive springs
FI:
FP RED Std housing
Braided oil line w/ filter
FP 02 Housing
OEM Ported Polished exhaust manifold
HP Wastgate Actuator
ETS 3" I/C w/ 2.5" short route piping
Brail small battery
Custom 3" straight turbo back exhaust
Synapse BOV
TurboXS Boost Controller
Interior:
Complete gut and removal of heat.. A/C.. Radio, ect..
Sparco fixed-back seat
G-Force 5pt Harnesses
Full 8pt cage
Exterior:
complete custom aluminum underbody
ARP CF diffuser
ARP GT front bumper w/ canards (fixing damage)
Wheels/Tires:
Enkei NT03+M's 18x9 or whatever deal I can find on similar wheels
275/40/18 race slicks or soft compound DOT's
Brakes:
Stoptech front BBK
Brembo GT rear BBK
All stainess lines
motul fluid
Suspension:
tanabe 7-series coilovers
pro 210 race springs
complete underbracing
sway bars w/o endlinks
perrin psrs kit
complete energy suspension bushings set
cusco strut tower bars
TEAS system
Drivetrain:
Exedy Twin Disc HD
Sheptrans stage 2 TC
Sheptrans stage 2 Transmission
Solid rear diff mounts
Perrin aluminum shifter bushings
short throw shifter
It will be tuned either through UTEC (what came on the car) or with a tactrix on C16.. Not to sure on numbers it will put out or if it will be competetive at all but its a budget build and it should be alot of fun to get done this winter
Old Oct 7, 2009 | 02:09 PM
Smike's Avatar
Theses threads are always annoying. Read the Motor Sports Forum. See what people are actually doing. Ask them questions. Read the big built threads there. Or find a car you have seen and copy their setup.
Secondly, I would not start off TT with all that. Start slow, go fast (later).
Closed.
