HID burnt out. Suggestions?
Old Nov 12, 2009 | 07:38 PM
Kemist's Avatar
Of course i want to upgrade, but not spend a fortune. Feedback, pics, vendors and generaly loads of info appreciated,
Old Nov 12, 2009 | 08:15 PM
iseedipp's Avatar
There's a vendor here that's doing like 60 shipped. Do you know if its the bulb or the ballast?
Old Nov 12, 2009 | 08:21 PM
mantosride's Avatar
i have a ballast for sale !
Old Nov 12, 2009 | 08:57 PM
Tangerine's Avatar
Do you know if it is just the bulb, ballast or both?
Old Nov 12, 2009 | 10:15 PM
iseedipp's Avatar
Swap your bulb that works with the opposite to find out
Old Nov 13, 2009 | 08:16 AM
Bobster22388's Avatar
If your looking for just the bulbs check out Ebay, they've got a lot of them on there and they are relatively inexpensive compared to ones you can buy anywhere else and you can still get whatever brightness you want also
Old Nov 14, 2009 | 09:32 PM
smarti's Avatar
fleabay has them 60 bux shipped. i put a set in the fogs
Old Nov 20, 2009 | 10:18 AM
Kemist's Avatar
thanks for the info, I got a full setup of 6k from 1320 at a great price. Now I just have to put them in.
Old Nov 20, 2009 | 10:43 AM
rcheung's Avatar
I was comtemplating getting hids for the fogs as well. Does a make a considerable difference as compared to the stock fogs?
Old Nov 20, 2009 | 10:46 AM
Genesis8's Avatar
Make sure to check if it's your ballast first. Found out the hard way and bought some bulbs and later found out it was the ballast. So I got a set of bulbs sitting around.
Old Nov 20, 2009 | 10:56 AM
EvoRob22's Avatar
Congrats. Let us know how the install goes.
Old Nov 24, 2009 | 11:33 AM
Kemist's Avatar
install was fine but had to splice some wires. Unfortunately they weren't plug and play. Now it seems they are aimed way to low. I have turned what I believe to be the adjustment bolt ( 10mm top of the back of the housing?) and nothing is adjusting- am I turning the right bolt?
