Upgrade path/advice
Old Dec 1, 2009 | 05:24 AM
asininedervish's Avatar
Upgrade path/advice
So, after having one of the top 5 moments of my life occur a week ago (evo paid off), i've decided to start planning out future upgrades. I am not looking for anything to insane, but a solid all-round upgrade. So heres what i'm thinking, all would probably be done at once. Any suggestions and comments are more than welcome.
Buscher Filter
Hallman Pro RX MBC
Walbro 255
MAP 02 Eliminator downpipe + Test pipe
AMS LICP
Swift swaybar set
ZT-2 AFR + DashDaq monitor
Pressure sensor (Boost)
Fluid temp sensor (Oil)
Fluid pressure sensor (Oil)
Forge BOV
The intent is to use the dashdaq + sensors to replace gauges. Car is an 03 Evo 8, came with a HKS carbon cat-back, so i should be set on that. If theres anything major that im completely missing, let me know! *fireproof suit on*
Old Dec 1, 2009 | 05:45 AM
JakeTheVIII's Avatar
I'd go with a real open filter rather than a drop-in. The MAF adapters are like $20, then throw a filter on there.
Any mbc should do the trick. The "pro rx" hallman isn't anything special. Go with what's cheap.
You need the Walbro. I like the MAP downpipe, and the LICP. The MR bov is a good idea.
I'd leave the dashdaq, swaybars, etc off there, probably won't do much. Oil pressure is probably more important that oil temp. Boost gauge is important.
Old Dec 1, 2009 | 05:53 AM
My understanding was that with the dashdaq i could effectively have a boost gauge, by installing a pressure sensor and routing it to the system? Not a huge fan of to many gauges cluttering the cabin.
Good advice on the filter. I'll prolly do that.
as to the MBC, i read a thread or two on having issues with strong enough springs, and it seemed that the hallman was a solid bet even on upgraded turbos.
Old Dec 1, 2009 | 08:36 AM
Kingofvacuity's Avatar
I have the forge mbc and it's worked great so far
Old Dec 1, 2009 | 08:59 AM
SRTRaceR04's Avatar
+1
Had a Forge and really liked it!
Old Dec 1, 2009 | 11:45 AM
GgreyEVOIX's Avatar
I didn't see it listed but if you are still on the oem clutch look into an aftermarket clutch to handle your new mods/power.
Old Dec 1, 2009 | 11:49 AM
chaotichoax's Avatar
your understanding is correct with the boost gauge function of the zt2
hallman or forge mbc are your best bet
Old Dec 1, 2009 | 12:48 PM
aschold's Avatar
By 02 eliminator downpipe, do you mean it's all one piece? That just sounds like a pain in the *** to me.
Old Dec 1, 2009 | 08:50 PM
Ehh, i've never pulled it on the evo, but exhausts arent usually to hard to deal with..
Course, im not sure if it really matters, but this way it actually has the full 3" diameter throughout.
As to clutch, i am still on the OEM. Think i'd really have to worry about slippage with those mods? Still on the stock clutch actually at 56k, and it still feels strong.
Old Dec 2, 2009 | 12:50 AM
aschold's Avatar
What I mean is, if you ever have to remove the turbo for whatever reason, you're going to likely have to remove that whole downpipe instead of unbolting two bolts where the 02 meets the dp. Like I said, pain in the ***.
Old Dec 2, 2009 | 11:23 AM
GgreyEVOIX's Avatar
My OEM clutch was good too, I had a little more miles on mine. I started modding @ 59K miles and after about 2 weeks the clutch started slipping. Use it for as long as you can but I'm pretty sure it won't last long just like mine.
Old Dec 2, 2009 | 12:32 PM
e\/olution's Avatar
add a good tune to the list
Old Dec 2, 2009 | 12:53 PM
F0RSAKEN's Avatar
Thats a good basic list, I did almost the exact same thing with only a few differences. I went with Defi gauges because I love 'em, and I would recommend getting Swift Spec-R's too, they're amazing, and the don't slam the car at all. Also may want to look into a slight performance brake upgrade to go with the added power.
Old Dec 2, 2009 | 03:14 PM
chu's Avatar
chu
Skip the Forge BOV and just get the oem Evo 9 one. What are your plans with the car? A daily driver, garage queen, road course, autox?
Old Dec 2, 2009 | 05:16 PM
JJLANCER02's Avatar
lucky, I got a year left of wounderful payment then i'll go hta green yea!
