Evo is still hestitating!!
1 Post
not a bad suggestion, i just did the treatment on my 91 TT stealth and it ruined a set of new plugs...sputters at high boost now, didn't immediately before the treatment for what it's worth.
I finally broke down and got some new spark plugs. I'm still having the same issue. I got some NGK iridium plugs that you don't gap. Any other ideas? I will probably take it to the stealership on Monday.
no such thing as "plugs you don't gap" once you start modding. since you mentioned you have a tune, your obviously not running stock boost & are probably way outside the spec that plug manufacturer had in mind when they set the gap at the factory.
do yourself a favor, buy a plug gapper. (there typically 99c for the cheapie, though id reccomend the feeler guages) it only takes about 30 mins to pull the plugs & check the gap. as most everyone has said, its pretty apparent that's the prob & if not, seeing as you dont know what your gap is set at, the first place to start is pulling the plugs & reading the gap so we can take that off the list
have you tried disconnecting battery for 10 - 20 minutes for ecu reset?
please dont change the turbo, thats like trying to solve an acne problem by getting a facelift. for now its overkill and may not fix it anyways lol
as said iridiums CAN be gapped. just treat it very delicately. instead of forcing the gap by using the gapper, use needle nose plier to slowly change the gap.
