2Step problem
Old Jan 4, 2010 | 10:43 AM
compscibOi's Avatar
Odd. Did you buy the car new?
Does the car start if you put the keys in, put the car in neutral and crank it without the clutch depressed? If it does start without having to push the clutch in, your clutch switch might have been disabled.
I know a few Supra guys who do that as their first mod.
Old Jan 4, 2010 | 10:50 AM
xtreme5369's Avatar
My clutch switch is not hooked up or it is bypassed since I have a remote start. My 2 step works fine still. I also have an ix. Just my 2 cents.
Old Jan 4, 2010 | 10:59 AM
04EBevo's Avatar
If you find that the clutch pedal is working then you need to be very easy on the gas until it hits 5500 then get on the pedal more. this is how I was taught by my tuner.
Old Jan 4, 2010 | 11:09 AM
MR Turco's Avatar
Originally Posted by Dr.Sound
i have an 05 GSR and mine is enabled from factory.
2003 and first half of 2004 (without ACD) did not have stationary rev limiter enabled from factory. latter 2004 and all 2005 8s did.
My mistake, all the 8s i have tuned have not had it enabled.
I didn't know 2004 models were offered with ACD either.
Old Jan 4, 2010 | 11:19 AM
gsrboi80's Avatar
It is just a stationary rev limit present and ENABLED in all roms 03-06. Just 03-04 had it set to a higher RPM then the regular rev limit
03-04 Stationary Rev Limit 7969
03-04 Rev Limit 7606
Old Jan 4, 2010 | 11:28 AM
Dr.Sound's Avatar
^ yep
Old Jan 4, 2010 | 12:10 PM
MR Turco's Avatar
Thats what i meant by not enabled.
Old Jan 4, 2010 | 12:24 PM
gsrboi80's Avatar
Not really sure why the heck they did that just to change it in later years??
Warranty Claims maybe due to kids dumping clutches at close to 7k rpm??
Old Jan 4, 2010 | 12:28 PM
Audi2Evo's Avatar
How often do you guys use the 2step? Ive done it once on my stock clutch and it stank bad. I did it the other night on my exedy stg I and it stank even worse. I dont like it
Old Jan 4, 2010 | 01:20 PM
oneofakindtrini's Avatar
Try the same steps, but bounce on and off the throttle up to 5500rmp.
Old Jan 7, 2010 | 06:08 PM
workel2man911's Avatar
+1
Old Jan 7, 2010 | 07:43 PM
hboy7777's Avatar
there are 2 clutch switches. one is up top behind the fuse box. this one was unplugged on mine and same thing happened. car started and acted just fine minus a throttle hang issue
Old Jan 7, 2010 | 07:52 PM
Evo1001's Avatar
try going to 7k to see if it's there. i had mine at 5300 stock working fine, then I got tuned and i thought it wasn't working any more. Then i realized it was moved up to 6000.
Old Jan 7, 2010 | 08:00 PM
Genesis8's Avatar
I've haven't used my 2step for like almost 2 years now. I might go try it out in the snow later to see if it works....
