2Step problem
Old Dec 8, 2009 | 10:01 AM
xxD3MONxx's Avatar
2Step problem
so i have my 2step set up at 5500rpm but the car just revs right past it
any ideas why??
Old Dec 8, 2009 | 10:03 AM
Kingofvacuity's Avatar
Make sure you're completely stoppd
Old Dec 8, 2009 | 10:05 AM
xxD3MONxx's Avatar
correct me if i am wrong
stop
1st gear
clutch in
rev to 5500
and then bam it should be there right??
Old Dec 8, 2009 | 10:07 AM
Yeah that's it. Bring it up, then let it drop then bring it up again..my car wouldn't bounce off the 2step the first time either sometimes
Old Dec 8, 2009 | 10:11 AM
MR Turco's Avatar
yes, that are the steps to getting it to work. If you are rolling what-so-ever it wont activate. Make sure you are completely stopped. You don't actually need the car in gear. Just make sure the clutch is to the floor.
I would also recommend easing into it. give it part throttle until you hit the 5500 limiter then ease onto full throttle.
xxD3MONxx's Avatar
nope still not working
my mind is blown
t3gr4's Avatar
I dont if this helps, but one time I didnt step on the clutch all the way down and it wouldnt do it.
Old Dec 8, 2009 | 10:16 AM
MR Turco's Avatar
i used to have intermittent times when it didn't work. Are you sure your clutch switch is plugged in? I forget which one it uses.
Also, what year is your car? Are you positive it is enabled? The 8s dont have it enabled from the factory.
Old Dec 8, 2009 | 10:18 AM
xxD3MONxx's Avatar
its a 06 and i have no idea about the clutch switch
and yea i am positive my friend pulled my map and its set at 5500
Old Dec 8, 2009 | 10:40 AM
evokid511's Avatar
sounds to me like the clutch switch isnt plugged in then if your map is set for it at 5500 then it should be there, hmm
Old Jan 3, 2010 | 10:06 PM
xxD3MONxx's Avatar
Sorry for bumping this thread back from the grave but can someone tell me were i can find the clutch switch and what i have to do to get it working
Old Jan 3, 2010 | 11:23 PM
ant_turbo's Avatar
Is ur speedo working? The reason I asked is I had the same problem with my friends evo,, the speedo plug wasn't pluged into the speed sensor,,, And 2step didn't work,..
Old Jan 3, 2010 | 11:41 PM
Dr.Sound's Avatar
i have an 05 GSR and mine is enabled from factory.
2003 and first half of 2004 (without ACD) did not have stationary rev limiter enabled from factory. latter 2004 and all 2005 8s did.
Old Jan 3, 2010 | 11:44 PM
Dr.Sound's Avatar
OP, are you on stock map?
did you buy the car new?
if no to either of those questions, then maybe your stationary rev limiter has been disabled or set higher than stock.
Old Jan 4, 2010 | 10:30 AM
felickz's Avatar
if the clutch switch isn't working then your going to have trouble starting your car...
unless you can start your car w/o your clutch depressed.
