Reverse lights stopped working?
Old Dec 8, 2009 | 12:52 PM
Darkn3s's Avatar
REVERSE lights dont work anymore.. not sure when they went out since its hard to see everytime u go into reverse.. i didnt see and fuses in fuse box for the reverse lights and checked all the ones under the hood, which all seemed fine
any ideas? i havent dont any electrical work lately which would cause it to go out
Old Dec 8, 2009 | 01:05 PM
Berts24's Avatar
could be the switch on top of the tranny
Old Dec 8, 2009 | 02:37 PM
nocabiwiksmx's Avatar
+1 had this happen before
Old Dec 8, 2009 | 03:23 PM
Bobster22388's Avatar
You did check the bulbs themselves 1st right?
Old Dec 8, 2009 | 06:34 PM
Darkn3s's Avatar
bulbs are good
which switch is this? anyone have a picture real quick
Old Dec 9, 2009 | 08:49 AM
http://images.wrenchead.com/smartpag.../DUS/C2216.jpg
http://www.autopartswarehouse.com/de...85c7ab9e&gan=1
Try that and see if the picture works
Old Dec 9, 2009 | 09:12 AM
Ev0ikon's Avatar
Reverse light switch under the steering column.
Old Dec 9, 2009 | 10:26 AM
Darkn3s's Avatar
Originally Posted by Bobster22388
and this is right ontop of the tranny like under the stock battery location?
Darkn3s's Avatar
where at? pics
Old Dec 9, 2009 | 12:14 PM
That's where all of the ones on the 1st gen DSM's were. I've honestly never really payed attention to the Evo tranny's to be sure about that one
Old Dec 9, 2009 | 01:42 PM
Ev0ikon's Avatar
where at? pics
It is been depressed by the brakes peddle in normal position. If you look under the steering wheel you will see.
Old Dec 9, 2009 | 01:49 PM
Ev0ikon's Avatar
mY BRAINFART!
I was thinking of the Brakes light. LOL
Old Dec 9, 2009 | 03:58 PM
mY BRAINFART!
I was wondering how something on the steering column or brake pedal would apply to something dealing with shift linkage and reverse lights
Old Dec 9, 2009 | 09:29 PM
Darkn3s's Avatar
checked the plug connector ontop of tranny and it is in real tight.. any other ideas..honestly im not sure when i could have happened
a buddy asked if i had red reverse lights when i was backing up and i was like noo should be white.. but yea still dont work
Old Dec 9, 2009 | 09:34 PM
Even though it is in real tight, as with all electrical parts they do end up going bad at some point. The switches are relatively inexpensive so you could try one. I would put the car in reverse while not running and check for voltage at the bulb sockets where the reverse lights are.
