Reverse lights stopped working?
Old Dec 14, 2009 | 09:57 AM
Darkn3s's Avatar
well i kno im not getting power sent to the rear, because i took the tails out and and put power to actual taillight harness to see if the harness on taillights would light up and it lite right up.. so its good on that end
anyone know the part number to the sensor/switch ontop of tranny
Old Dec 14, 2009 | 10:03 AM
Foolproof's Avatar
Pretty sure that was post #6 but here it is again http://www.autopartswarehouse.com/de...85c7ab9e&gan=1
Old Dec 23, 2009 | 05:57 AM
Darkn3s's Avatar
opps sorry
Old Dec 23, 2009 | 06:04 AM
jusa4bngr05mr's Avatar
I just ordered that switch aswell. When I installed my exedy twin, i saw that the switch was only holding on by a twinge and then the wires snapped right at the switch..... So hopefully I can get the new one and splice it in.
Old Dec 23, 2009 | 06:30 AM
Bobster22388's Avatar
Might be a bit of a pain to splice the wires back in if they snapped off that close to the switch itself, you could try finding that pigtail which will make the whole ordeal a lot easier or try some type of spade connector and slide them onto the pins and you don't have to worry about polarity with that type of thing either.
Old Dec 23, 2009 | 10:09 AM
GSX_TO_EVO's Avatar
Maybe i missed it but you did checl the fuse right?
Old Dec 23, 2009 | 05:02 PM
And that would be Post #1 of the whole thread. He stated that when asking his question.
Old Dec 24, 2009 | 08:51 PM
kaj's Avatar
kaj
my car is only 3yrs old and i've had to replace the reverse switch already. we did diag for a whole day before we came to the conclusion that the switch was the issue. LOL
we just figured "it's not that old. it CAN'T be the switch".
doh!
Old Dec 25, 2009 | 02:37 PM
1qwikef's Avatar
unplug the switch on the top of the trans and take a paper clip or something and jump the wires together and that will tell you if the switch is bad
Old Dec 26, 2009 | 08:30 PM
hang187's Avatar
Check the fuse. I had the same problem, check the bulb all was good, then the fuse. it was blown. replaced it and reverse light worked again. FYI the fuse is behind coin compartment labled "reverse". it uses mini fuse 7.5 amp
REVERSE lights dont work anymore.. not sure when they went out since its hard to see everytime u go into reverse.. i didnt see and fuses in fuse box for the reverse lights and checked all the ones under the hood, which all seemed fine
any ideas? i havent dont any electrical work lately which would cause it to go out
Old Dec 29, 2009 | 12:38 PM
Darkn3s's Avatar
fuse has been good
Darkn3s's Avatar
right now im dealing with a bad starter issue in the cold sucks for me.. ill worry about the reverse stuff after.. how much are they btw
ElectrIX Blue
Oct 5, 2017 08:16 AM
mstove
Lancer Troubleshooting
14
Jul 22, 2014 12:19 AM
KJS
Jan 26, 2012 02:36 PM
danielskshin
May 21, 2010 11:50 PM
sonicnofadz
Feb 28, 2006 02:42 AM
