Car won't turn over.
Old Dec 22, 2009 | 11:02 AM
el producto's Avatar
Question Car won't turn over.
Car cranks but won't turn over... failed fuel pump?
Old Dec 22, 2009 | 11:04 AM
rcheung's Avatar
It could be a ton of things. Did you scan the car for any codes?
Old Dec 22, 2009 | 11:11 AM
Bom's Evo's Avatar
AIR FUEL SPARK. Eliminate each problem to pinpoint it.
Does it try to start? Is the starter turning weak? Is there spark? YES OR NO?
Old Dec 22, 2009 | 11:22 AM
How can I check for spark?
It cranks until the battery slowly starts to die.
Old Dec 22, 2009 | 11:27 AM
nad17vtc's Avatar
Im guessing you can remove one coil, put a spark plug in it and let someone start the car and see if it sparks.
Old Dec 22, 2009 | 11:30 AM
Walt's Avatar
Take a plug out and put the boot back on it (with the wire, not coil pack) hold it against a bolt on the valve cover or something and have someone crank it over. Look at the electrode and see if u got spark. Good luck!
Old Dec 26, 2009 | 09:29 AM
okay so theres no spark.....
Old Dec 26, 2009 | 09:36 AM
binh's Avatar
Is it a stock motor? Built block?
Check crank and cam sensor next.
Old Dec 26, 2009 | 09:46 AM
Well I Checked for the spark and there was no electrode or whatever...
Changing the plugs won't help?... stock motor but I have cams.
Old Dec 26, 2009 | 09:51 AM
Ev0ikon's Avatar
Dead coil pack?
Old Dec 26, 2009 | 10:51 AM
What ohm range should the coil pack read...
Old Dec 30, 2009 | 02:20 PM
what OHM range should the coil pack be set at on the voltage meter??!?!?
