How do I spin this into a fun upgrade?
Something else to consider: If you upgrade the cams you'll have to tune for them which is an additional cost.
I'd almost rather gather all the ingredients, do one big install with cams, intake, exhaust, the whole works and get it tuned once instead of paying for a tune after cams and then after more upgrades as well.
An evo with a good tune and stock cams will make peak power around 6700-6950 RPM. It will still make peak power around 6900 after installing cams.
Each shift does not put you back 4000rpm. If you shift at 7k, you do not drop to 3k, that's ridiculous. Closer to 2000-2500rpm
Those are both false statements.
I read what you had to say and I just went for a cruise in my car. If I wind any gear up to 7000-7500rpm the next gear shift drops it down to 4500-5000 rpms. I don't know where you're getting your 2000-2500 rpm figure from. I can actually shift from 2nd to 4th and not even drop down that low closer to 3000-3500.
I may be a little off in my peak hp rpm figures but I just pulled them off the top of my head and the main principles of what I stated are true. Cams trade power down low for some up top and they hold HP better to redline. You get a much smoother climb in the torque curve that tapers less at the end and has a slightly higher peak in a notably higher rpm range more so in the torque curve than the HP curve.
