I am still trying to diagnose this problem. It is like a little whistle that only occurs when I'm at this speed coming from what it sounds like the right side? I have nailed it down to it being 3 things: The side of the front bumper is missing a couple of those pins that hold it together so it could be that. Or it could possibly be the brakes? Just weird why it would only give out the warning of wear only at that speed. Lastly sometimes I think its my HKS SSQV. That thing has been nothing but great to me and love it even though there are alot of negative sayings about it on this board.
Anyone have any thoughts?
Quote:
+1Originally Posted by evoracingstar
or could be transfer case whine.....
When I had a strange whistle that suddenly cropped up at 70 mph it turned out to be my transfercase.
My undertray would always whistle on the highway...mainly because it got shredded up at auto-x events. So I ripped it off and no more whistling
In all honestly, it could be anything. It sounds like it's just wind noise...
If u can't tell between gear whistle and wind whistle, u need a hearing aid
seriously though we'd need more info .... It could be anything
seriously though we'd need more info .... It could be anythingNewbie
Quote:
+2. been reading deep on transfer case problems on 03's-05'sOriginally Posted by evoracingstar
oh i know all about it man... i used to own a 03 evo 8.. they have the worse t case!! one day i was driving n all of a sudden i start hearing a whine noise.. i was like wtf is that.. then adventualy it got louder n louder. then i had to replace it.. thats nv fun bc t case r not cheap! but then i just ended up getting rid of that evo n bought a new 06 evo
good luck with the problem if u can try to make a video of the noise if its loud of enough im sure we could figure it out
good luck with the problem if u can try to make a video of the noise if its loud of enough im sure we could figure it outEvolved Member
If its not RPM related then its wind noise coming from either a broken undertray or your front bumper missing mounting pins.
Quote:
+1Originally Posted by kracka
if its not rpm related then its wind noise coming from either a broken undertray or your front bumper missing mounting pins.
Quote:
Well I've got a whistle at around 60 as well and it does get louder the faster I go. I'm thinking its the tcase, but I also did just lose my lip and the noise started around the same time. If I were to free rev the engine at this speed the sound doesn't get louder though.Originally Posted by Kracka
Could be your xfer case or wind noise then. What do you mean you lost your lip? If you're referring to your front bumper lip and it started at the same time as the noise then you've got your answer. A wind noise whistle or howl is far different from the xfer case mechanical whine. If you don't know how to tell the different find a competent mechanic to ride along with you.
The only way I can describe it is as if you were whistling very lightly. Doesn't sound mechanical to me. And it does not increase in sound as the RPMs rise so I really hope it is not the transfer case.
An 05 EVO with only 34k and the transfer out already! I hope not
I will pick up some of those pins from Napa Autoparts soon and see if the little whistle goes away.
Quote:
if u had a bad t case even if u free rev ur engine with out ur car movin u wouldnt hear it u have to be moving.. here a video of t case wine..Originally Posted by tripperfx3
http://www.youtube.com/watch?v=FdlocDJpfsI
The Transfer Case is the first thing that jumped into my head when I say thiss thread.
