Throttle sticking!!
Old Jan 28, 2010 | 07:13 PM
06RedRalli's Avatar
Throttle body shaft seals...prob worn out.
Old Jan 28, 2010 | 07:48 PM
EVO8emUp's Avatar
You're going to have to remove the t-body. the back side probably has extreme carbon build up on it. Mine did this. Use brake cleaner on it. That carb cleaner from advance sucks. The best cleaner I've used was Honda (motorcycle) carb cleaner, it takes it right off with little scrubbing.
tchouko, was the back side of your carb filthy?
Old Jan 28, 2010 | 08:03 PM
silver05evo8's Avatar
wow i have this same exact problem. it actually got real bad one day when i drove down the street and the throttle stuck open and i had to pull over. it was revving at 6700 rpms. im gonna have to clean it and let you guys know. i thought i was the only 1 with this prob.
Old Jan 29, 2010 | 05:03 AM
oneofakindtrini's Avatar
Originally Posted by esmjoe
+1...carfax..haha
+2
Old Jan 29, 2010 | 08:33 AM
Bobster22388's Avatar
Berkible 2+2 Carb cleaner also works very well, very little brushing needed to get everything out, I did mine just the other day
Old Mar 5, 2010 | 11:15 AM
Falcon350z's Avatar
What was the outcome with this? Mine has been getting progressively more annoying, though I haven't tried cleaning the throttle plate yet.
If it did work out, which cleaner did you end up using?
Old Mar 5, 2010 | 11:02 PM
dambikeracer's Avatar
Originally Posted by itsurismicah
maybe it's a toyota
+2
Old Aug 2, 2010 | 04:51 PM
4wd4me's Avatar
I have the same problem, I'll let you know what I find
Doug
Old Aug 3, 2010 | 01:51 AM
HaVoC187's Avatar
You might want to check your front O2 sensor.I had the same problem a while back and it turned out to be the O2 sensor.Easy way to check is just unplug the sensor and drive around a bit and see if it fixes the problem.
Old Aug 4, 2010 | 08:45 AM
jy951's Avatar
I had a slight sticking when going off idle. I went to replace my throttle body shaft seals and the back of the throttle plate was covered in soot. I gave it all a thorough cleaning with some brake cleaner that didn't work very well. After the cleaning, the throttle was much smoother.
You should be able to easily tell if its the cable or throttle body. Just remove the cable from the throttle body and you should be able to tell which is causing the problem.
Old Aug 4, 2010 | 08:51 AM
mifesto's Avatar
sorry i dont really believe you thoroughly cleaned your throttle body. you probably removed the upper pipe then sprayed alil cleaner and wiped the plate. that isnt good enough if its sticking, which mean its heavily gunked. remove the TB and do a real cleanup!
cassidyb
Feb 5, 2013 01:17 PM
EVOMIZ
Jan 27, 2011 12:57 PM
goofygrin
30
Feb 22, 2010 10:04 PM
EVO8emUp
Feb 7, 2010 10:23 PM
crcain
10
Nov 16, 2007 12:49 PM
