why is my car doing this?
Old Feb 16, 2010 | 12:40 AM
  #31
redhott92's Avatar
I occasionally have the same issue. My Evo 8 is stock... Just with downpipe, exaust, tial bov, and shep transmission and transfer case... I have NO idea what it is!!
Old Feb 16, 2010 | 06:59 AM
  #32
DFelton's Avatar
Mine did that and it was the throttle position sensor, but it threw a CEL.
Old Feb 16, 2010 | 08:28 AM
  #33
m34g63's Avatar
i hope its something simple. its so annoying.
Old Feb 16, 2010 | 08:31 AM
  #34
m34g63's Avatar
Originally Posted by Mark@AMS
You said the car had to codes.
P0113 - air intake temp. sensor one high output
P0107 - manifold absolute pressure. low imput
Try This.
Take the K&N cone off the MAF and make sure the screen on the MAF is there and not sucked in. (if the screen is gone you will need to find a new MAF). The screen being sucked in could possibly cause the problem your experiencing. Also check the plug on the MAF make sure it's plugged all the way in no bare wires etc..
screen is intact. everything seems to be normal.
Old Feb 16, 2010 | 08:50 AM
  #35
20gmr's Avatar
turn the boost down. I bet you it doesn't do it. Its not the pump regulator or injectors. it is a fuel issue but you arn't gonna solve it with parts. You need to either add time to the boost cut delay timer or turn the boost down.
Old Feb 16, 2010 | 09:29 AM
  #36
FJF's Avatar
FJF
Are you ever going to answer the questions regarding your tune?
Old Feb 16, 2010 | 01:22 PM
  #37
m34g63's Avatar
i believe the tune its all stock but i'm not positive. there is no boost controlller and i got the car the way it sits.
Old Feb 16, 2010 | 01:24 PM
  #38
m34g63's Avatar
how can i turn the boost down with no boost controller. or am i answering my own question.. haha should i buy a boost controller?
Old Feb 16, 2010 | 01:58 PM
  #39
turbotalawd's Avatar
Do you have a boost gauge? How much boost are you running?
Old Feb 16, 2010 | 02:11 PM
  #40
Got_Boost's Avatar
if you just bought the car why dont you call the guy you bought it off and ask him some questions? tell him to be strait with you so you dont screw up the car. ask what and when and what mods with the tune. you will need it redone if he put it back to stock form and just put a flash tune in. but i would call and get the low down... GL
Old Feb 16, 2010 | 02:13 PM
  #41
FJF's Avatar
FJF
yea most of the time the car runs great. it peaks at like 24 lbs. and tapers to 22 at wot. but like i said i dont know how else to explain it just sometimes, its like the fuel just decides to shut off and the car just falls flat on its face (no power) not just boost like the rpms go down of r a split second then it usually kicks back in. its like the car just turns off for a second then fires back up but its really annoying and frusrating at wot becaues its jerky.
You have no boost controller, you don't know anything about the tune, yet you're seeing 24PSI. It wouldn't be a bad idea to have the car looked at by someone who knows Evos. Good luck.
Old Feb 16, 2010 | 02:50 PM
  #42
BoostKid87's Avatar
you might have a boost controller in there somewhere. take a look. 24lbs is high for stock boost. i only spike 20lbs and drops anywhere from 16-19 depending on the gear i'm in.
Old Feb 17, 2010 | 03:08 PM
  #43
Mark@AMS's Avatar
Here is a few places in florida that could help you solve your problem. (sorry if i forgot any). Check them out.
AWD Motorsports
11530 Wiles Road
Coral Springs, FL 33067
Phone: 1-954 753-6006
www.awdmotorsports.com
Central Florida Turbo
651 N Goldenrod Rd. Suite 4
Orlando, FL 32807
Phone: 1-321-235-9959
Titan Motorsports
1714 Goldenrod Bldg A
Orlando, FL 32807
Phone: 1-407-977-9732
www.titanmotorsports.com
Old Feb 18, 2010 | 08:49 AM
  #44
m34g63's Avatar
bought it from a dealer. and they have no information about the previous owner.
Old Feb 18, 2010 | 08:55 AM
  #45
VIIIrs's Avatar
dude i'm positive if you get a tune it won't do it anymore
