My car will not shut off. Please help
Old Feb 20, 2010 | 05:07 PM
rsardelli's Avatar
I live in northern colorado. I have an 06 ix gsr. Lately when i turn my car off the turbo timer will wind down to 0 and shut the motor down. Funny thing is that my entire electrical system ie radio, heater, lights, gauges etc etc all stay on. I am having to jumpmy car almost every time i need to drive it. I need my car to be back to the fun loving car i used to know because as it sits right now it is just a pain in the ****. Any ideas. I am borderline desperate. I removed the turbo timer display but all the modules and wirin are still installed. Fyi. I have the apexi auto timer. Thanks all
Old Feb 20, 2010 | 05:10 PM
ak47po's Avatar
Does it shut off when you release the e brake.
Old Feb 20, 2010 | 05:11 PM
EvoFlash's Avatar
Remove the Turbo timer harness under the dash on driver's side look at a how to install one on evom.
See if that helps.
Old Feb 20, 2010 | 05:14 PM
ak47po's Avatar
This might help,just reverse the steps.
http://www.apexi-usa.com/content/pdf5492.pdf
Old Feb 20, 2010 | 05:15 PM
buchnerj's Avatar
I agree with EvoFlash. Someone wired up the turbo timer wrong. Trace the wires back and see where the power in is connected. Change the source.
Good luck
Old Feb 20, 2010 | 05:16 PM
rsardelli's Avatar
Thanks all. I will try thistomorrow when i can get some garage space. Right now. Snowing 5-7 inches accumulation so i wont be working outside for a while
Old Feb 20, 2010 | 05:17 PM
johnturbotron's Avatar
Take said turbo timer and sell it to a Honda fan boi.
Old Feb 20, 2010 | 05:18 PM
rsardelli's Avatar
Good question. No, its got a mind of its own. But i see what ur getting at. The tt would turn off when the ebrake was down. Now its on its own program
Old Feb 20, 2010 | 05:45 PM
rsardelli's Avatar
Good luck
The funny thing is that its been on my car for almost 3 years. And its just now deciding to start this
Old Feb 20, 2010 | 06:48 PM
TxFAkuma's Avatar
Yea this happend to me too.. i just reinstalled the turbo timer and boom never happend again.
Old Feb 20, 2010 | 06:54 PM
05BlackBeast's Avatar
Re-installation would seem like your best bet. When the weather gets better you will fix it no problem
Old Feb 20, 2010 | 09:53 PM
chaotichoax's Avatar
if you've had the turbo timer for awhile
check this first...
https://www.evolutionm.net/forums/in...s-how-fix.html
Old Feb 21, 2010 | 10:10 AM
monkey_187's Avatar
If it is not shutting off when it counts all the way down and when you release the parking brake then its wired wrong. You would have to check how it is wired, sounds like it doesnt have the harness. Check the connection at the parking brake under the console. There should be a wire splice there, it might not be making good contact. You should also check your ground, it sound like an easy fix. I had to rewire a friends TT cause the last person had it all messed up.
Old Mar 9, 2010 | 12:01 PM
EvoVan's Avatar
Sounds like a wiring fault. Just reinstall. If that isn't it then the timer is likely at fault.
beast66
Feb 15, 2016 12:51 PM
swanky
May 26, 2010 09:16 PM
Celica2EVO
Oct 17, 2007 07:18 AM
krazydan19
Jun 21, 2005 07:39 PM
