Needs Top-End POWER
Old Feb 26, 2010 | 08:45 PM
tdubbz's Avatar
Needs Top-End POWER
Coming from a S/C S2000 I am definitely missing the top end power with my VIII MR (I know apples-oranges) but How does one go about making big top end power with the VIII keeping the stock turbo and daily drivable......?
Old Feb 26, 2010 | 08:47 PM
kanyonkid's Avatar
big cams, boost
partyboy1122's Avatar
Cams, up the boost. You want real big power ditch the stocker!
Old Feb 26, 2010 | 08:49 PM
big block ix's Avatar
E85
Old Feb 27, 2010 | 03:31 AM
MR. EVO MR's Avatar
in my 05 mr the first mods were a whole bunch of bolt on with cams and springs, i raised the boost to 23 she felt incredible.
Old Feb 27, 2010 | 06:08 AM
SmurfZilla's Avatar
Fuel pump, injectors, stockframe turbo (BBK, HTA FP Green), E85, some Kelford 272/GSC S2's and a good tuner.
Car will be a different animal. I have raped many of a porche, vette's and even 1 viper on that setup.
Old Feb 27, 2010 | 06:13 AM
RockmanX's Avatar
you lie
Old Feb 27, 2010 | 08:02 AM
Appauldd's Avatar
If you want top end in an evo engine you will sacrifice low and mid range power. Top end power will come at the cost of lag.
If you really want the car to be fun to drive, tune it for the biggest power under the curve. After all, most of us spend the majority of driving in the mid rpm range, not the top end.
As others have suggested, cams will be in order. You really can't go wrong here. All cams help make power, but the ranges are different.
Turbo selection....well this is a different story. The larger turbos will certainly help in your top end goals, but the spool time will, in my opinion, make for a very "peaky" feel of a car. No power and the all of a sudden BAM massive power.
FP Green, or Red will net very good results without much loss in quick spool.
E85 will certainly help as well.
Search around and find the parts that will support your goal. We all have opinions on how you should go about it. Ultimately it is up to you on how you accomplish your goal.
Old Feb 27, 2010 | 08:08 AM
evo unknown's Avatar
Depending on what current modifications you already have I suggest,
cams (kelford 272/272 show the biggest power gain for evo 8s)
fuel pump (walbro 255)
turn up the boost (manual boost controller)
and a tune. Larger injectors are not really needed unless you upgrade the turbo or want to tune it for e-85.
Old Feb 27, 2010 | 09:44 AM
4RETECH's Avatar
If you have to keep the stock turbo and do not want to upgrade , at least cams, fuel pump, licp, intake, tbe, and a very good tune.
Old Feb 27, 2010 | 10:57 AM
MADMarc's Avatar
Arent you guys' gears super shot because they came from the rally background? 6 speeds, what speeds do they take you to?
Old Feb 27, 2010 | 11:04 AM
Evo IX MR's Avatar
1st 40
2nd 60
3rd 85
4th 110
5th 130
6th 165-170
Old Feb 27, 2010 | 01:32 PM
Originally Posted by hydroshock
hes going out and raping slow sti's, evo's stangs, cameros left and right
Old Feb 27, 2010 | 01:50 PM
chaotichoax's Avatar
search for more
closed...
