Well, today I started pulling it all apart.
here is what i found, looks like a torque tube that goes from the center diff to the transfer case shattered, cracking the TC cover, bearing race, outer torque tube, and wedged into the TC carrier. the end of the tube is still down in the center diff. tomorrow when i get to the shop ill check the spiders in the TC carrier.
pics...
pics...
Anyone run into this before? Any company make upgraded parts for this situation or should i just go OEM? would hate to do this twice :/
i have heard of it before..you should try evoempire.org. its a norcal evo site. some guys had the same problem and i think they got an after market that suppose to be a lot stronger.
sweet, since Im already replacing the parts, Id much rather go stronger
Ouch, totally sucks.
And like someone said..... time for an upgrade! Woohoo! =)
If you preload on the e-brake this type of failure usually won't happen unless you are making lots of torque.
Call Shep and tell them about your situation. John is knowledge and can replace that case and probably other parts too. Goodluck.
Thats awesome
, If i was you i just start saving for a built setup.
But good luck man
, If i was you i just start saving for a built setup.But good luck man
damn in nervous now. i have the same clutch with about 1000 miles on it and 65k on the rest of the car and with what will be a lot more power than stock shortly
the fiance will kill me if i break it knowing (not knowing) how much $$ ive spent on the evo in the last few months
GL with the fix homie
Spoke with John at Shep yesterday.... sent out the TC and center diff to him today. Should hear something in the next few days.
He mentioned they make an upgraded torque tube
