HELP: bumper bracket relocation
Old Mar 8, 2010 | 02:48 PM
Paulito's Avatar
I have a set of 18x9.5s et 20 and a 265 tire, they rub a little and they are mostly rubbing on the bolt, my fenders are rolled tight.
So i heard people relocate this bracket? is there a diy? any pics?
any help would be awesome, thanks
Old Mar 8, 2010 | 03:37 PM
chaotichoax's Avatar
as far as I know there is no info on here about relocating the bolt other than the mention of having it done
most body shops would do it...from what I understand is that it isn't that difficult but is time consuming
Old Mar 8, 2010 | 04:48 PM
Paulito's Avatar
yeah i know i been searching and found just comments.
im not concerned about getting it done, i would like to just see what im getting into and if anyone had any advice.
like is repainting the bumper involved? i heard people overheated the tab or something...
also if what suspension and camber.
Old Mar 8, 2010 | 05:44 PM
the bolt is on the inside of the fender area so repainting the bumper is a definite no
suspension and camber wise...you'll have more room to play with
Old Mar 8, 2010 | 06:42 PM
Paulito's Avatar
o ok, i thought there was a plastic bracket on the bumper that needed to be moved...
i guess im going to give it a shot tomorrow. im probably going to take some pics and male a diy or something.
thanks for your input...
any one else, possibley some pics?
Paulito's Avatar
also does anyone how much rear camber i can get out of stock arms and struts in the rear?
Old Mar 8, 2010 | 06:48 PM
Appauldd's Avatar
What "bolt" are we talking about. I have 265s with rolled rears and no rubbing.
Please give some more details on this.
Old Mar 8, 2010 | 06:52 PM
Paulito's Avatar
towards the back of the inner fender well close to the outside and top of bumper.
whats your setup, suspension, width and et?
Old Mar 8, 2010 | 06:55 PM
Appauldd's Avatar
18x9 +30. I am on Tanabe GF 210 springs.
Are you talking about the front fender area??
I think maybe you are lowered too much.
Old Mar 8, 2010 | 07:03 PM
Paulito's Avatar
nah im talking about the rear. im only on hotchkiss springs, same drop, its just the offset. i poke a little over 15 mm more than you.
what about your alignment? stock specs?
Old Mar 8, 2010 | 07:31 PM
Appauldd's Avatar
alignment.....-0.9 camber in the rear - 1.9 camber in the front. 0 toe all around. Nearly perfect cross camber too.
you may need to go to 255s or roll your rears a bit more...maybe even a little stretch.
Old Mar 9, 2010 | 12:21 AM
boostin350z's Avatar
Noez, dont stretch!
Old Mar 9, 2010 | 02:57 AM
Paulito's Avatar
trying to avoid stretch at all costs. its not a vw haha
Old Mar 9, 2010 | 06:39 AM
Appauldd's Avatar
Your wheels are wide, your offset is low, and your tires are wide......something has to give if you plan on running with stock panels.
I am not a fan of stretch either.
phrequenc
May 26, 2011 09:29 AM
SilvrEvoIX
Aug 26, 2009 07:24 PM
evo3matt
Mar 14, 2006 04:05 PM
AlwaysinBoost
10
Oct 30, 2004 04:41 PM
