Defi Boost Gauge Adjustment?
Old Mar 9, 2010 | 09:57 AM
bboy_RES's Avatar
i have the Defi Link Meter BF boost gauge and the needle doesnt sit at zero when i turn the gauges on. it sits around 1/2 psi. i'm curious as to if this can be adjusted and the gauge can be zeroed out. i just want to make sure that my boost gauge is reading correctly rather than reading 1/2 psi than what it actually is.
Old Mar 9, 2010 | 10:04 AM
metal4all6's Avatar
Mine is the same way. When the car is off and you have the key turned to power the accessories, it reads 1/2 psi.
Old Mar 9, 2010 | 10:54 AM
revvin9k's Avatar
There is a ZERO out function for the Defi's. I don't remember it off the top of my head, check your manual or Defi's web site.
Old Mar 9, 2010 | 11:13 AM
bboy_RES's Avatar
aight i'll check their website. i think i threw my manuals away. haha.
Old Mar 9, 2010 | 11:17 AM
Go_Lancer_Go's Avatar
keep us posted
Old Mar 9, 2010 | 11:35 AM
bboy_RES's Avatar
i didnt see anything on their website. i'll try to contact them directly.
Old Mar 9, 2010 | 11:41 AM
UT_Evo's Avatar
If it's a BF link, it should be able to be zeroed out, you just have to figure out how. It does the self test when it starts up, right?
Old Mar 9, 2010 | 03:11 PM
revvin9k's Avatar
I'll let you know when I get home and I'm able to access the manual.
Old Mar 10, 2010 | 02:06 AM
bboy_RES's Avatar
yeah it does the self test and everything. i know i can set the warning value, but i'm not sure how to actually zero out the gauge. then again, i havent actually tried to zero it out using the control unit II.
Old Mar 10, 2010 | 02:07 AM
bboy_RES's Avatar
please let me know what you find! thanks.
Old Mar 10, 2010 | 06:40 AM
revvin9k's Avatar
Sorry for the delay, knew I had it some where.
If you are using 1st generation control unit
(1)Turn your ignition switch to "ON" (but do not start engine)
(2)Select your Turbo gauge to configure warning value (LED on Turbo
gauge
blinking fast)
(3)Press REC and PEAK switch same time more than 2 seconds.
(4)Finished learning Zero point.
If you are using 2nd generation (=Control Unit II) control unit
gauge
blinking fast)
(3)Press REC and DOWN switch.
Old Mar 10, 2010 | 07:38 AM
bboy_RES's Avatar
thanks a lot man! i'm gonna try this as soon as i put reconnect my battery. i just finished installing my invidia o2 housing and my battery is still disconnected. haha.
Old Mar 10, 2010 | 09:18 AM
metal4all6's Avatar
Thanks! I'll try this out when I get home tonight.
gauge
blinking fast)
gauge
blinking fast)
Old Mar 10, 2010 | 11:39 AM
bboy_RES's Avatar
gauge
blinking fast)
gauge
blinking fast)
worked like a charm! thanks!
Old Mar 10, 2010 | 12:50 PM
revvin9k's Avatar
No problem, I had the same issue before. Glad it fixed it.
