Oh no ACD lights are all on!!
So today I was driving and I noticed that all of my ACD lights were on. I pulled over and shut the car off and turned it back on. Seemed fine for about 2 min and then they came on again. I checked the ACD fluid and it is at max. I have about 22k miles on it but I shouldn't have to change the fluid for another 8K. I read that sometimes it can be ABS sensors and I am going to check those tomorrow. I really need to do my breaks do you guys think that the breaks being close to gone could cause this? Any other ideas?
Thanks,
Josh
Thanks,
Josh
Did u mess with your throttle position sensor? I put on a ported TB and because I didn't put the TPS back in the right position all 3 lights pop on EXACTLY like your's does. After about 2 mins of driving.
Has it been warmer in Chicago lately? My ACD works fine in the winter months, and then all the lights come on in the warmer months. From what I've read this is due to the pump failing to make the required pressure to satisfy the system pressure relay. In short, the pump is bad. I've also read of people adding oil thickeners to get more time out of it. This is why it works in the colder months....colder oil has much thicker viscosity.
So today I haven't had any issues with it. I disconnected the battery and cleaned my air filter. I guess we'll see how things go over the next few weeks. I'm replacing pads and rotors tomorrow since mine are totally shot. I'll keep you guys up to date.
Yeah I hope so. The part is on order right now so they said that it should be here next week. I do have another question though. The dealer told me to take the car home and driving it until they replace the pump is fine. Is that true? Am I going to damage anything else if I continue to drive it??
