I over filled my oil?
Old Mar 11, 2010 | 04:52 PM
  #31
cinek's Avatar
you are fine,when i do it and i use mobil1 ep 1qt bottles i try to leave 200ml down on the bottom in my fifth bottle,this way is closer to 4.8qt and its just above the top line
Old Mar 11, 2010 | 07:11 PM
  #32
04Evo851374's Avatar
absolutely fine
Old Mar 11, 2010 | 07:20 PM
  #33
TTP Engineering's Avatar
4.33 qts + oil filter. Overfilling can cause the crank to splash in the oil in the pan and hamper performance. It can also churn up the oil and aerate it, hampering lubrication.
Old Mar 11, 2010 | 07:56 PM
  #34
rush63's Avatar
Originally Posted by chaotichoax
do I have the only evo that doesn't burn through oil?
my oil level never changes
my sti was a different story however
You're not alone
Back to topic. I use a large syringe with a hose attached to it to suck the remaining oil after dripping. There's more or less 100 ml of old oil left after the last drop fell from the oil pan (with front tires on ramps). I prime the filter, pour in 3 quarts plus the remaining oil from priming the filter, lower the car, wait for an hour or so to let the oil settle (with engine off, of course) and fill up to the MAXIMUM level on the dipstick. Less than 5 quarts in all.
Old Mar 12, 2010 | 03:45 AM
  #35
prodigy1210's Avatar
No harm in checking for foamiing on the dipstick. TTP Engineering guy prolly knows more than anyone else here and he has the same warning. Just check to be safe..
Old Mar 12, 2010 | 04:55 AM
  #36
yahu's Avatar
OP - did you prime the filter? That filter holds a decent amount of oil if you allow it to fill. If adding 5qts on top of that, I'd be a little worried.
Old Mar 12, 2010 | 06:32 AM
  #37
5LEEPERISAH23I's Avatar
YES!! i agree.. I had a sti and it burned oil... Evo when i check doesnt.. .it stays the exact same... i guess it depend how u drive it
Old Mar 12, 2010 | 06:41 AM
  #38
no i didn't do that.. 5qts including the filter.. i checked my dip stick after hard turns kind of and accelerating hard.. no bubbles or dots on the dipstick.. u know what later today ill take a pic of my dipstick.. that would make life alot easier..
Old Mar 12, 2010 | 06:42 AM
  #39
yahu's Avatar
^ah, you are probably fine then. 5 straight qts, no bubbles, I think you're gtg. Pix won't ever hurt though.
Old Mar 12, 2010 | 10:35 AM
  #40
boostedwrx's Avatar
I;d take the filter off, let the oil drain out then put the filter back. I'm OCD about my oil level though so it's always at the full mark.
Old Mar 12, 2010 | 10:37 AM
  #41
yahu's Avatar
^I'd sooner pull my drain plug out a bit. Easier to clean, IMO. I can't stand it when I get oil around the filter.
Old Mar 12, 2010 | 10:40 AM
  #42
boostedwrx's Avatar
Yea or that - I can be quick with the drain plug too!
Old Mar 12, 2010 | 01:53 PM
  #43
dasmyevo88's Avatar
anything more then what you did would be dangerous but your good dog
Old Mar 12, 2010 | 02:31 PM
  #44
19DB794's Avatar
My Evo doesnt burn oil either. My dip stick always stays at the same level. I usually put in just under 5 quarts and that includes using a new oem filter.
Old Mar 13, 2010 | 04:36 AM
  #45
Ur fine dude.. As long as no dots or bubbles
