The big horsepower question?
Old Mar 29, 2010 | 05:03 PM
From 3 to E's Avatar
Originally Posted by Mikerock
I think carroll shelby had said it "horse power sells cars, torque wins races"
this is why im on the fence getting rid of the bbk full. it makes good torque, but its limited to 4xx hp/tq, whereas a bigger turbo could go to 6xx hp/4xx tq at a higher rpm.
Old Mar 29, 2010 | 05:21 PM
allister's Avatar
k bye
Old Mar 29, 2010 | 06:20 PM
asubennett's Avatar
Its all about area under the curve and your useable powerband.
If you BBK makes say 400ftlbs at 3800rpm that is great and yes a bigger turbo might only make 325ftbls at 3800rpm. That is where you decide what your motor use is and what your useable powerband is.
If your motor can support 9K rpm then a powerband from a big turbo that makes 325ftbls at 3800 rpm and 400 ftlbs at 4400 rpm and 475ftbls at 5000rpm and the resulting horsepower from the equation in the first post etc would be amazing.
I think the OP has good intentions of trying to understand how numbers work with each other, but ultimately he failed to express goals or a desired accomplishment from the info he is obtaining.
Old Mar 29, 2010 | 06:30 PM
McLaren F1 2003's Avatar
This.
Old Mar 29, 2010 | 07:25 PM
merlin00069's Avatar
Originally Posted by scorke
What you've just said is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul.
Scorke
It's from Billy Madison. Very niiiice.
Aww dammit i just read that others saw it before me. Still very nice.
silkey00's Avatar
i obviously have a lot more to learn... :-(
Old Mar 29, 2010 | 07:56 PM
this. in relation, this is why i found this particular statement caught my eye:
" 'It's better to make torque at high rpm than at low rpm, because you can take advantage of gearing.' For any given level of torque, making it at a higher rpm means you increase horsepower"
and yes, i know someone else already posted it..
Old Mar 30, 2010 | 02:27 PM
stevef's Avatar
Neither of the two (high rpm torque or low rpm torque) is better. Just different. low rpm torque will serve you better on the street because you normally would drive slow. but on the track, you want to be revving as high as you can without going out of your powerband or breaking your motor, so having a high rpm powerband will be in your favor as you won't be ever below 4500 rpm.
Old Mar 30, 2010 | 02:37 PM
Evo_Jay's Avatar
Scorke
One of the best quote in all of the Adam Sandler movies.
Scorke FTW.
Old Mar 30, 2010 | 02:42 PM
MitsuOZ's Avatar
for some reason after reading this i think the core concept is misinterpreted which in the long run, is making less and less scene the more and more i read
moparfan
Mar 18, 2021 10:28 PM
R/TErnie
80
Jan 7, 2021 02:46 PM
ouminan
GSC Motorsports - Charleston, SC
Jan 9, 2015 10:48 PM
WhtEvo05
50
May 2, 2008 05:17 AM
EVOBOYUK
Dec 28, 2007 02:20 PM
