would a leaking o2 housing
I would have to say a leaking o2 housing wouldn't cause the plumbing to not hold boost because once the exhaust gases get past the turbine blades, whether they go out the turbine blade through the primary port on a stock o2 housing or through the wastegate side once the flapper opens, they have already done their job as far as propelling the compressor wheel.
I would get it fixed ASAP regardless though.
its like the car hits full boost and it slowly makes it way down to 15 psi and holds there
i will fix it as soon and my parts get here. somehow the bolts backed out and all i see is 2 bolts holding it on and even they were about to fall out. luckly i caught it before everything fell out
after thinking further about it, this is a stock turbo or stock appearing turbo with an internal waste gate correct? If the exhaust gases are escaping, that would explain why your boost is trickling down after it hits peak - then falls.
I would get it closed up asap bro.
Also, what about your wastegate spring? Hook your WG up to a pressurized system with a pressure meter to find out if it leaks under pressure.
thats exactly what i was thinking.
parts should be here tomorrow to fix everything up, when its all good. i will let you guys know if this is the problem
glad you found it and it didn't hurt anything
FS[West]: Titek O2 Housing , OEM IX Bov
EvoEi8ht
10
Apr 29, 2016 11:30 AM
4doorstreetbike
Sep 8, 2010 07:35 PM
