Help , car engine rough idle and bog after TBE install.
I don't know what I did but after installing my txs TBE on my evo 8, I decide to take
it for a few test run.
at the 3rd run I pull on about 4k rpm on 1st gear , I hear a loud "CLING" like something blow off.
after that the car would shake if tries to run normal mph on all gears.
The car idles real rough , bogs alot and black smoke blown from tail pipe.
look under the car , everything looks in tacked.
Did you hear the loud clink noise only when you get on it hard or just that one time like something fell off the car? I can't think of any reason just changing the exhaust would cause the car to act like that. The only thing your doing is increasing the flow so it would cause the boost to be higher which means the car would be lean without a tune.
godnf8
17
Jun 28, 2010 04:48 PM
godnf8
17
Jul 25, 2009 04:46 PM
