Emergency Diagnosis For Evo VIII
Old Apr 7, 2010 | 07:41 AM
mostafa911's Avatar
Hey i bought a 2003 evo 8 with 40,000 miles im having weird problems when i start the car and its cold it will shut off unless i keep reving it untill its warm...Also when i floor it the car is really slow... I asked the previous owner he said it needs a tune because there used to b a bigger turbo setup that was removed and now has stock turbo no tune any body know whats wrong...
Old Apr 7, 2010 | 07:46 AM
firebad's Avatar
If the previous owner is correct the current map (A/F, timing,etc) will be way off for your car.
It may be dumping a lot of fuel at low rpm causing the engine to stall out...
That could be one of many scenerios...Drop it off at a good shop and give them as much info as you can. Good luck.
Old Apr 7, 2010 | 07:47 AM
FedEvo8's Avatar
Yes, it is the tune. Bring it to your local tuner and they should be able to fix everything. It would be wise to do a boost leak test before the tune as well.
Old Apr 7, 2010 | 07:59 AM
binky's Avatar
If it has the stock turbo on it (stock injectors?) - I would download a stock ROM for your car. This way you would be able to drive it. Do you have a Tactrix cable that you can use (or access to borrow one)?
Here's the link to the ROM's
http://evoecu.logic.net/wiki/Downloads
-Bink
Old Apr 7, 2010 | 08:17 AM
gsrboi80's Avatar
Get it flashed back to stock as others have said. Then take it from there. I'm in NNJ if you need it flashed LMK
Old Apr 7, 2010 | 08:38 AM
mostafa911's Avatar
the car has all bolt ons and 750cc injectors im actually taking it to ivey on friday just wanted to make sure cars not messed up
Old Apr 7, 2010 | 09:15 AM
Bobster22388's Avatar
Check to see if you have any boost leaks also.
Old Apr 7, 2010 | 09:26 AM
lemmysports2's Avatar
what he said. always a good idea to make a boost leak tester before you head out for a tune.
Old Apr 7, 2010 | 07:35 PM
dmcghie's Avatar
even if you dont get to test for a boost leak, take it to ivey....sean will be able to sort out the minor issues and get it tuned properly. I had a similar issue with mine, went up there and they realized i had a major boost leak, car went from dynoing at 240 to 310 at the wheels after fixing it.
Old Apr 10, 2010 | 09:37 AM
mostafa911's Avatar
yea i took it to ivey the car is perfect thanks guys
