Mini Battery Problems...
Old Apr 9, 2010 | 03:15 AM
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by ball7068
Talk to Batteries Plus. We use them for our UPS systems at work. If you give them the size/specs. they can find you a good replacement battery. When my mini-battery fails, that's where I am going to go. Odds are, they are going to be a lot cheaper than going back the the shop that sold you the kit.
Actually I got my battery from batteries plus
That being the only problem with the mini battery so far, I will keep mine, stuff happens sometimes...
Old Apr 9, 2010 | 04:35 AM
jmelocik's Avatar
Good attitude to have. Most people forget that we drive highly modified cars and when you do that you have to expect certain issues to pop up. We are lucky though, we have a lot less issues then some of the other modified cars on the road and we make more power per liter than most.
I have been running the Enersys mini battery and never had a problem until I came back from deployment and it hadn't been started for a while. (Girlfriend was starting it once a month and driving it around about the same). SHE ordered up a new one for it and although it looked identical it was just a little taller. (like 1/8th of an inch) This caused it to not fit in the bracket quite right so I had to modify it slightly. No issues since then.
Josh
