Missfire until 20miles
Old Apr 9, 2010 | 12:17 PM
aronmatic's Avatar
I have missfire until i make 20 miles. after 20 miles its starts to clear and leave the missfire. i have new greddy spark plugs, but same thing was before. the car has only 45k miles, 2003 evo 8.
any idea?
Old Apr 9, 2010 | 12:21 PM
u189961's Avatar
i know you mentioned that you had the misfire before the greddy plugs but have you gapped the plugs? have you checked for any loose hoses? is the car throwing any cel lights?
Old Apr 9, 2010 | 12:25 PM
aronmatic's Avatar
i checked the gaps on the new plugs of corse. i had flash cell light before, but i changed the bov and that is fixed. the funny thing is, why runs perfect after 20 miles? the coils looks ok.
Old Apr 9, 2010 | 12:29 PM
IrightI's Avatar
any idea?
Make sure the car is completely up to temp before you romp on it. The ECU doesn't use the front 02 sensor to control the fuel maps until your engine reaches a certain temperature. So until then, it pretty much guesses, and runs pig rich.
Old Apr 9, 2010 | 12:33 PM
u189961's Avatar
is you car tuned? perhaps it has something to do with the timing down low?
have you taken a look at the MAF sensor to see if its dirty or something? perhaps a boost leak somewhere?
Old Apr 9, 2010 | 12:35 PM
SavEVOIX's Avatar
Than the issue should be constant instead of resolving it's self after 20 min. I think it's either an ECU or cold spark plug issue.
Old Apr 9, 2010 | 01:15 PM
aronmatic's Avatar
the car now ecuflashed to 1,5 bar peak and 1,3bar at redline, but did the same thing, when it was full stock. i have aem uego in my car. it shows rich, (10.0afr) when do missfire. same afr, when its cleared. i loged with ecuflash. its dont shows anything. no knock, only 1 or 2 knock sum.
Old Apr 9, 2010 | 01:18 PM
kwanza's Avatar
Maybe the coil is starting to fail?
I just had one go bad at 67k. In my case it worked fine unless you were in full boost. It is easy enough to check if you have a friend with an evo by swapping out coils.
Old Apr 9, 2010 | 06:43 PM
snailman83's Avatar
have you tried anything?
Old Apr 9, 2010 | 09:33 PM
aronmatic's Avatar
yes. i will try the coils next week.
Old Apr 10, 2010 | 04:09 AM
06mr775's Avatar
So what you are saying is your car holds 10.0 AFR at full throttle even after it stops misfiring?
Old Apr 10, 2010 | 07:23 AM
aronmatic's Avatar
the aem shows 10.0 afr when its missfiring and the same thing, when dont.
Old Apr 10, 2010 | 10:36 PM
aronmatic's Avatar
Originally Posted by euntaeyi
modlist please.
3"downpipe back, walbro 255 pump, lower ic pipe, greddy sparkplugs., k&n air filter.
maped 1,5bar
same thing was, before the mods.
Old Apr 20, 2010 | 11:52 AM
aronmatic's Avatar
problem resolved. i installed my standalone ecu.
thanks guys the helps, but maybe some sensor was bad.
Old Apr 20, 2010 | 02:05 PM
DSMraver's Avatar
Sounds like the tune, IMO... But glad it's fixed!
