Plug wire Test
Old Apr 9, 2010 | 02:34 PM
Appauldd's Avatar
Plug wire Test
So I got a great deal that I couldn't pass up on some Ralliart plug wires.
Upon getting them I tested the resistance of them vs. the stock plug wires. Needless to say I was shocked at the results.
STOCK
Long = 5420 ohms
Short = 2590 ohms
Ralliart
Long = 300 ohms
Short = 145 ohms
Now I am curious if I can open my plug gap a tad because of the vastly lowered resistance in these new wires.
Yes, I realize that COP is the way to go and options out there are getting cheaper every day. I just wanted to post my observations.
Paul
Old Apr 9, 2010 | 02:45 PM
Walt's Avatar
That's some good info, thank's for the test
Where did you get the wires? Might have to pick some up.
Old Apr 9, 2010 | 02:48 PM
Appauldd's Avatar
Sorry....I should have said......Ebay.
Old Apr 9, 2010 | 02:55 PM
Walt's Avatar
That's cool, ebay's good for some stuff. Thank's
Walt
Old Apr 9, 2010 | 03:25 PM
nonschlont's Avatar
interesting...
link?
Have u driven w/ them installed yet? Any difference?
Old Apr 9, 2010 | 03:30 PM
Appauldd's Avatar
Sorry....no link. Some one was selling a set.
I have not driven them yet. I will report when I do.
I do not believe I will really notice much since I run an HKS DLI II. This was an impulse buy seeing a deal that was pretty darn good.
Shocked the heck out of me that the stock wires have such high resistance. So....I had a second set sitting under my work bench...tested the same. Talk about crappy wires.
Old Apr 9, 2010 | 03:35 PM
JFuego777's Avatar
Some of that resistance is there to help prevent interference with electronics. You may hear a snapping from your speakers that matches your engine speed with that low of a resistance wire. Not sure, but the ralliart wires might be designed to be used with spark plugs that have resistors built in...Definitely let us know if you notice anything with the wires, good or bad though.
Old Apr 9, 2010 | 06:56 PM
Appauldd's Avatar
Went for a short drive and the results are.....
Smoother idle is clearly evident
AFR is a tad leaner at cruise
Fuel trims at idle adjusted slightly
These could be placebo because of slightly cooler weather. I cannot determine the plug wires are the cause. Regardless.....I like them.
Old Apr 10, 2010 | 08:32 AM
suekie's Avatar
Its the shielding in wiring that helps with interference with electronics. The amount of resistance does not affect this at all!
Old Apr 10, 2010 | 08:48 AM
Chabada15's Avatar
Old Apr 10, 2010 | 08:53 AM
JFuego777's Avatar
Really?
Read this article. http://www.magnecor.com/magnecor1/truth.htm
Try making sure you know what you are talking about before you chime in next time, thanks!
Old Apr 10, 2010 | 09:40 AM
euntaeyi's Avatar
It's not a placebo when the variables in your test are measurably different.
There has to be a reason why Mitsu engineers used wires at those resistance ratings. I'd be more wary of placing wires that have less than 10% of the resistance rating of the OEM ones.
You referenced that page detailing the implications of high vs. low resistance wires. Seems like you missed the section starting with "Low-resistance conductors." I recommend you re-read the page.
Old Apr 10, 2010 | 10:09 AM
Appauldd's Avatar
Ok Ladies....no more pissing contests....sheesh. I just wanted to state my observations.
After a couple days of driving I can verify the car does in fact rev a little smoother and idle a bit smoother.
Old Apr 11, 2010 | 08:34 PM
JFuego777's Avatar
Not to continue the pissing contest, but the reason I posted a link to that article is in response to the statement "The amount of resistance does not affect this at all!" Besides that fact, the section you are talking about is talking about solid core ignition wires, which had 0 resistance, which were used on race cars back in the days when they didn't use solid state electronics that EMI/RFI could interfere with...that is why there was no need for suppression. We are talking about daily driven street cars with loads of solid state devices, which solid core wires are not suitable for. Anyway, I say if you like the wires and they aren't causing any issues, go with it.
Old Apr 11, 2010 | 09:09 PM
xRoguex's Avatar
How old were your stock wires? My stock wires began to be out of spec after about 25-35K...
