Help identifying plug/wire on steering wheel column
Old Apr 26, 2010 | 11:11 AM
tboboy's Avatar
Hey guys, can someone help me identifying this plug/ wire and where it is supposed to be plugged into? Its coming out of the steering column. Thanks
Old Apr 26, 2010 | 11:19 AM
MR.O's Avatar
That looks like a harness plug for a turbo timer... Is you evo used?
Old Apr 26, 2010 | 11:22 AM
JakeTheVIII's Avatar
Looks factory, not like a turbo timer. It probably plugs in somewhere right around there. Usually the female end it plugs into is about as far away as it will reach, and that should be the only plug that fits the female end...Probably some sort of light/steering/horn/something like that.
Old Apr 26, 2010 | 11:46 AM
Bobster22388's Avatar
Definitely looks like the wiring coming off of a turbo timer before if gets to the adapter for the specific car, especially having that type of nylon'ish' cover around the wires. Did you trace the other end of it to see where it went?
Old Apr 26, 2010 | 11:49 AM
tboboy's Avatar
From the first look I didnt see the other connecting point. Car was used but stock. Not sure about the turbo timer, maybe there was one before. I thought someone could easily pin point this. Ill look around later tonight. Thanks
Old Apr 26, 2010 | 11:50 AM
MR.O's Avatar
Actually with some certainty I can say that is the plug to a HKS MT-6 Harness
