Spark Plugs & Gap
Old Apr 29, 2010 | 07:54 AM
fastsrt4u's Avatar
Question Spark Plugs & Gap
Guys,
I'm looking to replace my plugs in my car... I'd like to know what type should I get, and where should the gapping be?
These are my mods: 3'' exhaust, with 3'' downpipe, and test pipe, Intake, upper/lower intercooler pipes, bigger intecooler, ECU flash, 255 fuel pump, evo 9 bypass valve... lo boost at 19psi and hi boost at 21psi.
Any imput will be greatly appreciated.
Thanks
Old Apr 29, 2010 | 08:15 AM
TouringBubble's Avatar
NGK BR7ES @ .026 should do fine for you. If you're not used to running copper plugs, know that they need to be changed often ... every oil change is common.
Old Apr 29, 2010 | 05:14 PM
fastsrt4u's Avatar
what brand do u recommend aside from copper plugs?? Are Ngk's ok?
Old Apr 29, 2010 | 05:31 PM
Acree's Avatar
Every oil change? I've never heard of replacing spark plugs every 3,000 miles. That's ludicrous.
-Acree
Old Apr 29, 2010 | 05:40 PM
xxthayxx's Avatar
NgK BR7ES(part #5534) are fine for stock hp. they are cheap...i replace them after every oil change.
Old Apr 29, 2010 | 06:44 PM
Ivan B.'s Avatar
People replace them with every oil change because they foul easily.
Old Apr 29, 2010 | 06:50 PM
chaotichoax's Avatar
op, you need to search...plenty of plug info on this forum
-Acree
copper plugs it is common
iridium you can run much much longer
