had the car for 12 hours and now it wont start! PLEASE HELP!!
Old May 3, 2010 | 03:28 PM
sstrobl's Avatar
sure as **** it was a fuse, so i replaced it and it fired right up, but it burned out another one today, any ideas why its burning them out?
Old May 3, 2010 | 03:29 PM
sstrobl's Avatar
it has some hks spark enhancer box, which my buddy said he hasnt heard much good about so we bypassed that and it still burned one out, and yes it pulls like a freight train, i had a 400hp trans am, feels nothing like this
Old May 3, 2010 | 03:37 PM
SilverShadow03's Avatar
**EDIT - Just read a fuse was/is the culprit...
Same happened to me except it died on me shifting from 1st to 2nd....it turned out to be the balance shaft belt going out and taking the Crank Positioning Sensor with it. I ended up doing an entire timing belt/balance belt replacement along with water pump and the parts that gave out...wasn't cheap but I ended up doing it with a friend and saved a lot of money that way...
Good luck and let us know what the cause was once you figure it all out!!
Old May 3, 2010 | 05:28 PM
heavens turbo's Avatar
which fuse is blowing? whatever fuse it is, you can most likely follow that system to the culprit, be it a rubbed wire, ground, or something in the system thats bad. good luck!
Old May 3, 2010 | 05:57 PM
Boost_Inspired's Avatar
you have a grounding issue somewhere , some wire could be pinched and bare wire is touching metal and popping the fuse to that circuit.
Old May 3, 2010 | 06:03 PM
AndyBandy's Avatar
i had the same issue, it happened to be the exhaust where the rear o2 sensor was rotated up and rubbing on the heat shield under the car. I know the HKS exhaust is notorious for this issue.
Just a thought, but worth a check
Old May 3, 2010 | 06:50 PM
bboy_RES's Avatar
my first thought was that your ignition fuse (20amp) under the hood was blown. i had the same issue with my car last month and that was my issue. it kept blowing everytime i turned the key to the on position. my issue was my o2 sensor wiring. when i extended the wires the shrink tubing that i used melted through and the wires were grounding out to each other. if you have an aftermarket o2 housing you should check your o2 sensor wiring.
Old May 3, 2010 | 08:12 PM
brtecson's Avatar
Well at least you know what the problem is now :/
Old May 3, 2010 | 08:21 PM
Roberti22's Avatar
+1
check out the wires
Old May 3, 2010 | 09:50 PM
ev0lution9's Avatar
check your PM
Old May 3, 2010 | 09:58 PM
sstrobl's Avatar
yes its the ignition fuse, it doesnt go out everytime, it runs great for like 50-60 miles give or take and then it just dies when i come to a stop, ill take a look at the wiring tomorrow, its gonna be awesome since its a heavily modded car with someone else who did the wiring lol, tthanks for the suggestions guys ill let you know if i find anything. i love how quick you guys are to help out with an opinion, im glad i oined the evo community : )
Old May 4, 2010 | 03:36 AM
AndyBandy's Avatar
the 50-60 miles is exactly what mine did too
Old May 4, 2010 | 11:30 AM
boozeup&riot's Avatar
awesome that you were able to find it so quickly. Good luck with your fix!
Crucifer
Aug 17, 2015 04:47 PM
jackbenimbo
Feb 21, 2015 12:33 PM
EvoDan2004
73
Oct 27, 2009 03:21 PM
maxiav
Mid-Atlantic Region
69
Sep 3, 2009 08:34 AM
DocCola
May 9, 2008 04:51 AM
