Need help with Transmission
Old May 11, 2010 | 12:11 PM
9SECndEVO's Avatar
Sounds like your clutch is worn and either your tob popped off or the plastic clip that holds your shift cables broke. I would check the shifter cables inside the car before anything else.
Old May 11, 2010 | 10:27 PM
pennies_hatchie's Avatar
Well, the clutch was replaced just 10k ago by the previous owner (I have the receipt for the work) and its an exedy single carbon clutch.
I will check the shifter cables. Any other Ideas. Again, it drives fine (slips past 3k) once in gear and in order to get it in gear, the car has to be off, other then that, the shifter is just mush.
Old May 13, 2010 | 11:42 PM
i found these 2 threads and this is exactly my problem
https://www.evolutionm.net/forums/ev...to-gear-3.html
https://www.evolutionm.net/forums/ev...neutral-2.html
god, i just dont even want to think about it right now.
Old May 17, 2010 | 01:08 PM
well, i just finished the carnage (about 5 hours of work by 1 guy isnt too bad)
turns out the clutch is gone. nothing left of it and it was bare metal. guess its time for new one.
Old May 17, 2010 | 09:09 PM
btw, it had the part number
TA093 for the clutch and H22504 for the pressure plate and its an exedy. Weird cause I cant find anything online for it.
Old May 23, 2010 | 09:57 PM
well found out that its an exedy hyper single clutch like this one
http://www.prostreetonline.com/x/exe...clutch-kit.asp
and it looks to be a rebuildable kit. now, i cant find anywhere online on where to buy the disc. anyone have any clue and how much. thanks in advance.
Old May 24, 2010 | 06:24 PM
nobody?
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
EVOlutionary
Sep 28, 2011 07:14 AM
Mellon Racing
55
Oct 18, 2008 04:57 PM
KazzEvo8
10
Jan 24, 2007 12:37 PM
Warrtalon
20
Nov 28, 2006 08:57 PM
