Radiator Fan Control Module
Old May 19, 2010 | 03:44 PM
miller121mx's Avatar
Quick question - I have an 03 Evo, and the intercooler sprayer has been removed. Will that leave a connector on the fan control module unused? I had everything apart for a while and just putting it together now. I can't seem to find any cable to plug in there. The only thing I can come up with is that it was for the sprayer, unless I'm completely missing a cable tucked in and hiding somewhere.
Old May 20, 2010 | 03:23 PM
Nobody knows? Can someone just go look at their car for me and let me know. It's the little black square shaped thing aside of your radiator fan. There should be two connectors with cables coming out the bottom of it. Just tell me if there's an unused connector sticking out of the passenger side of it.
Old May 20, 2010 | 09:42 PM
lcwjr's Avatar
The fan control module on my '04 Evo 8 has an unused connector, and two harness plug connectors. One goes to the fan motor, and the other is wired into the front harness. I removed the inter-cooler sprayer, etc. some time ago, and the wiring does not plug into the fan controller. If you look inside of the "extra" plug receptacle on the controller, I think that you will find that there are no metal contacts in it. I guess there might be some other application that uses the same controller.
ahmedshaikhani
Aug 24, 2021 10:24 PM
Dambay
10
Jul 9, 2013 03:30 PM
bnr34rb26dett
10
Nov 16, 2012 05:50 PM
chrisff521
Aug 29, 2011 07:41 AM
Torque07
For Sale - Part Outs
25
Jul 15, 2011 07:59 AM
