04-06 Ralliart Engine/Drivetrain (no forced induction)
Coolong Fan Module bypass???
Old Jul 6, 2013 | 06:25 PM
Dambay's Avatar
Hello i recently acquired a 2004 ralliart and my cooling fans are not working (at all). Neither the A/C fan or the cooling fan work. From reading through the forums i basically deduced that my fan control module is no good. Rather than replacing the module id like to bypass the controller and run the fans through a set of relays. Im wondering if anyone on here has a wiring schematic for the cooling fan module and a pinout of the ecm; or have attempted to bypass the controller without hard wiring a manual switch inside the car (i dont want to have to worry about switching my fans on)
Old Jul 6, 2013 | 06:54 PM
CrAnSwIcK's Avatar
just get a new module...they're $90 shipped
no sense adding relays, because you would still need some kind of control module to control them or the engine will not keep constant optimal operating temp.
Old Jul 7, 2013 | 09:49 AM
RalliartN's Avatar
^^ this. Want optimal fan operation. If you used the car only in the summer or year-round in warm weather then directly hardwired fans would probably be okay, but if you drive in cold climates/winter then for sure replace the controller.
Old Jul 8, 2013 | 01:56 PM
Dambay's Avatar
Managed to find a module from an 04 MPV. (Mpvs ran a similar calsonic cooling system for that year. Modules are the same) At least everything is working while the new one ships.
Old Jul 8, 2013 | 03:29 PM
rzrxn's Avatar
This temp fix actually worked for you? So you basically took a 2004 Mazda MPV module and hooked it up to your RA? Wow, never thought of that. Has that been covered? I didn't even search yet but just thought I would ask
Old Jul 8, 2013 | 04:49 PM
Raikiri's Avatar
I can't imagine that things like that module would be exclusive to only so it doesnt surprise me. Just need to figure out which cars share it I suppose.
Old Jul 8, 2013 | 10:22 PM
Dambay's Avatar
Yep. Works like a charm. Couldn't find a scraplancer or outlander anywhere near me but after some digging found that the MPV module is the same.
Dambay's Avatar
Worth noting I guess
Old Jul 9, 2013 | 06:22 AM
rzrxn's Avatar
Nice, maybe I'll do the same with mine before I order a new one. I will look around in my local wrecker and I'll see how if they have any. If they're cheaper than the OEM ones, and works the same way, I will grab as much as I can and give it to anyone who needs one. Good find, bro!
Old Jul 9, 2013 | 03:29 PM
Dambay's Avatar
Thanks. Glad to help.
Old Jul 9, 2013 | 03:30 PM
Dambay's Avatar
I believe they were in the 04-06 MPVs.
JDavenport
Apr 29, 2017 12:43 PM
Eleventy5
Lancer Troubleshooting
Oct 1, 2015 12:24 PM
88888
Jun 13, 2013 08:40 PM
foxbear2277
Aug 16, 2012 05:09 PM
toxic-evo
AEM EMS
Mar 16, 2012 02:20 PM
