HELP! drivershaft
Old May 28, 2010 | 09:45 AM
domantas's Avatar
HELP! drivershaft
OK, I had this whining sound coming from the rear end. I just replaced my T case with the new one, so its not it. I have heard the improperly installed driveshaft could make noise. I had my driveshaft disconnected while doing the t case install, but I probably misaligned the driveshaft the way it came out. How do I line up the front end of the driveshaft to the rear end of the driveshaft?
Old May 28, 2010 | 09:47 AM
9SECndEVO's Avatar
If everything is bolted up in the stock locations it should line up, if it's whining its cuz you don't have enough fluid in it and it's probably already damaged.
Old May 28, 2010 | 09:48 AM
thedru13's Avatar
^X2. did you tear the Oring on the Tcase? Are you leaking fluid? I would start there
Old May 28, 2010 | 09:56 AM
domantas's Avatar
how do I line up the driveshaft? My fluids are fine. T case is brand new... no leaks
Old May 28, 2010 | 09:57 AM
thedru13's Avatar
The drive shaft should go in after you bolt the Tcase on and have the tranny on the car. If those 2 are done the drive shaft should just slide in. Is that not the case?
Old May 28, 2010 | 10:02 AM
DarksideZ's Avatar
Once you bolt everything up properly there is no need for any allignment.
Old May 28, 2010 | 10:13 AM
domantas's Avatar
On the video that explains t case removal, it says to mark the driveshaft the way it came out. My t case and trans is in the car. The front end of a driveshaft slides in the t case and the other end needs to be bolted down to a rear end with 4 bolts. Rear end must be bolted down in the same way it came out, I have heard this in number of sources, they recommend to mark it down before you take it out, but I didnt I might have to just try reinstall it couple times, to see if noise dissapears.
Old May 28, 2010 | 10:17 AM
thedru13's Avatar
Wait not sure we are talking about the same thing. Are you talking about the Drive shaft the goes into the Transmissoion and into the Tcase or the Drive shaft that runs under the car from the TCase to the Rear of the car..
Old May 28, 2010 | 10:28 AM
turbotalawd's Avatar
You mean halfshaft? No, hes not talking about the halfshafts.
Hes saying that he removed the DRIVESHAFT, from the tcase to the rear diff, and he thinks he installed it wrong and thats why its whining.
OP: You could try and remove it and switch the position of the driveshaft. Also check your rear diff fluid. Didnt you mention in another thread that it was bone dry before or am i mistaken?
Old May 28, 2010 | 10:32 AM
thedru13's Avatar
Ok Sorry my ADD kickin in reading to quick.. It still should line up no?
Old May 28, 2010 | 10:37 AM
Ya it should line up fine, but if its installed in a different position it COULD cause vibrations and/or noise.
Old May 28, 2010 | 12:41 PM
domantas's Avatar
I only removed front half of the driveshaft that connects to the tcase. On one end it slides in the tcase, on the other end it has 4 bolts connecting to the rear half of the driveshaft (that is the location that needs to be bolted down same way it came off) I'll just try to reinstall it and see if that helps, if not, most likely its my rear end cause i drove the car for 2 miles with no fluid in the rear end...
gotta wait for my block to get back from the shop that is getting a full rebuild... this car eats my money big time...
Old May 28, 2010 | 12:57 PM
ODUB's Avatar
well, if you'd just leave it alone and drive it (and remember to refill fluids), things wouldn't break, and it wouldn't eat any extra money at all.
remember that before you start complaining about the car. good luck with the fix.
Old May 28, 2010 | 01:15 PM
domantas's Avatar
^^ thanks, im upset because i bought the car with no turbo, no seats, no tcase in it, so i tought ill replase them and be set.
So i had no idea lsd was bone dry, that motor had a spun bearing, that all the wheel bearings needs to be replaced, blah blah
Old May 30, 2010 | 11:57 AM
Boost_Inspired's Avatar
sounds like the rear diff is toast
