Rear wiper delete fluid issue
Old Jun 2, 2010 | 09:41 PM
badev0's Avatar
I removed my rear wiper assembly but now have to figure out what to do with the line. Does the front and rear fluid sprayer lines run off the same fluid reservoir? I'd still like to be able to use my front sprayers, but obviously when you spray the front, the rear sprays as well What can be done so only the front sprays and not the rear line?
Old Jun 2, 2010 | 09:56 PM
Bobster22388's Avatar
They run off of the same reservoir. They are also separate washer pumps, so you can just disconnect the one to the rear wiper and leave it in place.
Old Jun 2, 2010 | 09:58 PM
TommiM's Avatar
Your rear wipers should not be squirting when you use the front squirters.
Old Jun 2, 2010 | 10:15 PM
badev0's Avatar
Alright thanks.
And yes, if you squirt the front, the rear squirts as well.
Old Jun 2, 2010 | 10:25 PM
AznEvoIX's Avatar
Mine don't. I have no idea what you are talking about.
Push the bar forward for the front washer fluid.
Twist the knob on the bar for the rear.
They are completely separate.
Old Jun 2, 2010 | 10:30 PM
badev0's Avatar
When I push the bar forward, both squirt.
Old Jun 2, 2010 | 11:43 PM
AznEvoIX's Avatar
Thats not supposed to happen.
Your Evo must have the Orgasm mod installed.
Old Jun 2, 2010 | 11:46 PM
wreckless969's Avatar
Old Jun 3, 2010 | 12:20 AM
evoforlife's Avatar
thats weird check the pump and see if anyone rewired something
Old Jun 3, 2010 | 12:22 AM
TS8's Avatar
TS8
Definitely has separate control circuit.
Somehow your Evo has had rear end work and wired incorrectly.
Definitely does not squirt together stock, which can be proved via wiring circuit from
the Tech manual.
Old Jun 3, 2010 | 05:27 AM
badev0's Avatar
Yeah that is pretty weird. I did not know it was not suppose to squirt when the front did. It was pretty damn annoying though thats for sure. Where exactly is the second pump located so I can disconnect it?
Thanks guys.
Old Jun 3, 2010 | 05:31 AM
jasserv's Avatar
thats is hilarious!!!!, thanks for the laugh, i needed it this morning..
Old Jun 3, 2010 | 05:38 AM
badev0's Avatar
Loooool orgasm mod ftl.
Old Jun 3, 2010 | 06:47 AM
limp_noodle's Avatar
second pump for the rear is installed in the rear resivoir right next to the front pump. they look the same, but have different colored connectors.
Old Jun 3, 2010 | 07:33 AM
badev0's Avatar
Thank you sir.
