My VIII is down with a blown motor!
Old Jun 13, 2010 | 08:12 PM
  #46
RockmanX's Avatar
Originally Posted by drewdq
I would really like to do this myself, but I don't have a garage and I don't feel comfortable leaving this in my driveway in pieces for weeks.
I bought a $1400 99 Nissan Pathfinder and I've contacted Ivey for some pricing. I'm still leaning towards a 2.4/FP black setup for the near future...
yea get yourself a built std 2.4 like my build. Personally i would never go back to stock block. you have time now so just build it up right now. you said you got you a secondary car so you have time. with that aggressive tune you might as well get a setup that can handle that and the stocker is not that. Come join me and mikeys 2.4 fp black army
Old Aug 14, 2010 | 07:41 PM
  #47
Sinbig's Avatar
Did you ever figure out what to do. Curious.
Old Sep 9, 2010 | 12:55 PM
  #48
teribble's Avatar
Any update?
Old Nov 13, 2010 | 07:35 PM
  #49
drewdq's Avatar
Update: I decided to go with an FP Black/2.4L Build. For the last 4 months I have been gathering parts:
SBR Stage III 2.4L
  • OEM 100mm Crank
  • Manley I Beam Rods
  • Manley 9:5 87mm Pistons
  • ACL Race Bearings
  • ARP Mains
  • AMS Custom HG
  • ARP L19s
  • OEM water pump with spacer
  • OEM Oil Pump Assembly
  • OEM 4g64 Timing Belt with new tensioner, idler pulley, idler belt
  • Balance shaft and oil squirters removed
  • New OEM Oil Cooler
  • OEM complete gasket set
  • EGR Block plate
Headwork by Ron Whitney, fully rebuilt/ported
  • Manley springs, titanium retainers
  • Manley valves, 1mm oversized
  • 3 angle valve job
  • Kiggly HLA
  • FP4R Cams
Intake/Turbo
  • Ported FP Black with install kit
  • Ported stock intake manifold
  • Mil.Spec 65mm throttle body
  • Muse short route UICP
  • Buschur LICP
  • FP Intake pipe
  • Perrin Air Filter
  • ETS 3.5 FMIC
  • Forge RS BOV
  • Hallman Pro MBC
Exhuast
  • MAP Tubular Exhaust manifold
  • FP Exhaust Stud kit
  • Megan O2 housing
  • Megan Downpipe
  • Straight pipe
  • HKS 3" Exhaust
Drivetrain
  • Shep Ultimate Ratio Trans
  • Shep Stage III Transfer Case w/ LSD
  • Quartermaster Twin Kit (used 2k miles)
  • New AMS motor mounts (3)
Fuel
  • Buschur Double Pumper (installed)
  • FIC 1650's
Other
  • Gates upper/lower Radiator Hoses
  • Spoolinup COP
  • AMS small battery tray
  • MAP small battery
  • AEM Wideband
  • AEM Boost gauge/controller
  • Stock ECU Tephra V7 (with MAF for now)
  • Shockproof Light Gear oil x3
Old Nov 14, 2010 | 12:14 AM
  #50
BuBBasEVO's Avatar
Curious how much all that stuff run you?
Old Nov 14, 2010 | 01:12 PM
  #51
drewdq's Avatar
Without the transfer case, FMIC, and wideband all of this cost me about 15,000 just for the parts. Many misc parts I purchased were used too. $4000 was on the motor stuff, $1700 on the headwork, $1800 on the FP Black and kit, $2000 on the trans work, $500 on the exhaust manifold, $500 on the Double pumper, $500 on cams, $700 for a used QM clutch kit, $400 for injectors, $300 for an oem oil cooler, and $300 for a Mil.Spec TB just to name some big items off the top of my head. I have a complete spreadsheet put together if anyone is interested in why a 2.4 build can be so costly. I was told I can do it for 8K, but I figured I wanted to do a lot of other things correctly while I'm at it.
Old Nov 14, 2010 | 01:15 PM
  #52
drewdq's Avatar
This thread can be continued here, in my 2.4/FP Black build thread.
https://www.evolutionm.net/forums/ev...ack-build.html
Voltexed
Dec 8, 2016 05:56 AM
slimjim1804
For Sale - Cars For Sale
38
Feb 9, 2013 05:50 AM
FX11
Oct 28, 2011 07:11 AM
bryantbesu
May 27, 2011 04:31 PM
zoso
15
Jan 2, 2011 01:39 AM
