weird shifting problem
Old Jun 14, 2010 | 01:20 AM
CaptainEVO's Avatar
Question weird shifting problem
hey im a noob at this just got my evo a while ago
and still trying to figure everything out
so dont flame me please.
so anyways when im driving when i put it in 3rd
it kinduh grinds a little bit wondering if some one can tell
me what im doing wrong or if its the car. thanks.
Old Jun 14, 2010 | 01:35 AM
Pal215's Avatar
just third ? I would try adjusting the clutch pedal travel so that it allows for an earlier engagement and disengagement when pushing the clutch pedal. This might fix the grinding problem. Heres how:
https://www.evolutionm.net/forums/ev...djustment.html
By referring to the picture in the link, you want to adjust it so that the push rod goes in the deepest.
Old Jun 14, 2010 | 07:16 AM
jam05pr's Avatar
^+1
I have had to do the same thing. Its really easy once you get in there and see it for yourself.
Old Jun 14, 2010 | 07:29 AM
XxApollynxX's Avatar
If you adjust the pedal and it still happens a grind while shifting into the gear usually means the syncro is on its way out. It's also possible to have a bent shift fork but you would have to have the trans taken apart more then likely.
Old Jun 14, 2010 | 07:45 AM
Locdizzel's Avatar
try solid sifter bushings, that help me out a lot
Old Jun 14, 2010 | 07:49 AM
mikevoviii's Avatar
by referring to the picture in the link, you want to adjust it so that the push rod goes in the deepest.
+2
Old Jun 14, 2010 | 07:51 AM
thedru13's Avatar
I have the 6sp and mine does the same. Its not a grind but you feel the gears when I shift. IDK i have tried everything mentioned and the result is the same. And My trans was rebuilt.
Old Jun 14, 2010 | 08:39 AM
SavEVOIX's Avatar
Everybody always says bent shift fork but can our forks even really bend? They are cast iron and thick as hell.
Old Jun 14, 2010 | 02:35 PM
cssaddictm4's Avatar
I broke mine in half...They may be strong, but still have a weak spot.
OP: Try to flush the transmission fluid and see what it looks like. Make sure to use stock fluids (in my opinion).
Old Jun 14, 2010 | 06:42 PM
MitsuJDM's Avatar
Welcome to the lovely world of Evo's.
Both of mine have done this and never got worse. It was an intermitent problem. It's a very small, hardly noticable grind. If it's REALLY bad grind, the a synchro is bad.
Old Jun 15, 2010 | 09:30 AM
CaptainEVO's Avatar
thanks everyone ;]
Old Jun 16, 2010 | 07:24 PM
negativegeforce's Avatar
Don't let anyone tell you this is normal. The transmission should never feel like its grinding into gear or have an audible sound. Try changing the transmission fluid. I recommend Amsoil 75W-90.
In the case the transmission is fine, its also possible the gear is partially being locked out at higher rpm's because some aftermarket clutches can tend to stick to the flywheel at higher rpm causing syncro wear/gear grind/gear lock out. If you have an aftermarket clutch this may be the case, but this is usually caused at very high rpm.
Old Jun 16, 2010 | 07:39 PM
Probably is a syncro, but trying a transmission oil change is better then pulling the trans out...
Old Jun 16, 2010 | 07:43 PM
SLO-EVO's Avatar
sounds like you need to replace your 2-3 synchro.
Old Jun 16, 2010 | 09:26 PM
intuition_d's Avatar
Yep.. that happened to me. Spontaneous grinding, bad synchro. Not the end of the world
