Yet another problem with my evo8 after a rebuild.. lf advice.!
so after a long wait, my car finaly comes out the shop.....
evo8
2.3l
35r
1000cc
255walbro
272/272 hks cams
koyo rad ......
Anyway, first day a wire caught shortage on the cam sensor wire and car ran on 3 cylinders for about half a mile. Figure it out, fix it and continue to drive around... next day i go start the car, and after turning it on, put it into first, 3 seconds later it shuts off, little smokes comes out from under my hood and wont start again.. take the car to the mechanic and apparently my engine wiring harness fryed!
suggestions? Try and fix it? Get a whole new enging wire harness?
anyone know where i can get this? im guessing dealer would be my best bet?
any advice appreciated
dj
evo8
2.3l
35r
1000cc
255walbro
272/272 hks cams
koyo rad ......
dj
Its not really a hard job its just time consuming. You basically will have to just trace every part of the harness to disconnect every connector and ground. It could end up being a little bit of a pain cause it runs into the firewall and may run under the intake.
awesome!!! thanks to everyone. I contacted the dealer today and apparently the entire engine bay harness is made up of 5 different harness's, so hopefuly the one i have to replace isn't to much of a pita. The engine harness on ebay looks real good thou.
ill keep you guys updated how things are going, now i gotta go order some parts.
thanks again
dj
Your mechanic should be fixing this stuff. That isn't something that "all of a sudden fails", maybe he left something off/disconnected or routed something too close to something hot?
He's a good mechanic with a good eye for detail, always makes sure everything's good. Only thing that's been wrong with my car is the temp gauge would go up when i'd turn the heater fan's on, but it was weird because my temp gauge would go up when my car wasnt even ON, just the keys turned and fan's on.... I hope i can somehow figure out how exactly this happened, but no clue how im gonna do that.. sigh
If he does the work, i dont mind paying for the harness, just sucks i have to go through this...
its broken!!-dj
