Trouble after timing belt replacement?
Old Jun 25, 2010 | 02:40 PM
blitzkrieg79's Avatar
Hey Guys,
Few days ago my dealership replaced my timing belt and ever since then whenever I make an all the way turn to the left or right, there is a noise as if the timing belt was slipping or something (high pitched sound). Could this be related with timing belt? Or could it be just coincident and something else is happening? Or maybe during timing belt replacement, mechanic damaged something by accident? All I know is that there was no noise before timing belt replacement. Any help would be appreciated. Thanks.
Old Jun 25, 2010 | 02:56 PM
TIBOevo's Avatar
do you drive evo X?
Old Jun 25, 2010 | 03:01 PM
PeteyTurbo@KHC's Avatar
Could be a dirty accessory belt
Old Jun 25, 2010 | 03:06 PM
Jp7's Avatar
Jp7
um, correct me if i'm wrong but evo 10 has no timing belt, only a timing chain.
Old Jun 25, 2010 | 03:25 PM
Oh, don't let my avatar fool you lol It's just a regular Lancer 2004.
Old Jun 26, 2010 | 10:12 AM
barneyb's Avatar
My guess is that a greasy handed mechanic put the accessory belt back on and now, when the PS pump has to work hard the belt slips. If the tensioner is okay the best fix now is a new accessory belt.
Old Jun 28, 2010 | 11:22 AM
Kevmac3685's Avatar
Sounds like the accessory belt like everyone says. I just replaced all those belts yesterday (12 hr. job NEVER AGAIN lol.) You should replace you accessory belt every 30,xxx recommended. Or it can be your power steeering pumps but I think you would notice that if it was leaking or needed more fluid.
Old Jun 28, 2010 | 05:40 PM
MitsuJDM's Avatar
This was my exact thought.
Old Jun 28, 2010 | 09:20 PM
goldenEvo's Avatar
Is it fix yet?
Old Jun 28, 2010 | 09:28 PM
Bggstin's Avatar
Originally Posted by blitzkrieg79
Hey Guys,
Timing belt is not slipping or else you would have a nice set of bent useless valves. I would tighten the accessory belt and spray it with belt dressing afterwards. Should be problem solved.
Old Jun 30, 2010 | 08:01 AM
MitsuJDM's Avatar
Belt dressing is messy. Try a bar of soap.
