Transfer Case Problem
Old Jul 2, 2010 | 06:15 PM
toyotabike's Avatar
I read a lot of threads about people having transfer case problems and whine, but I wanted to know how often does it occur.
If you dont abuse the car all the time and just daily drive it, can this be prevented?
Old Jul 2, 2010 | 06:31 PM
apagan01's Avatar
treat the car nicely and it will last you, dont launch at every corner, do more gear pulls than launches and it will last you, change your fluid often.
Old Jul 2, 2010 | 06:37 PM
SLO-EVO's Avatar
that.
do proper maintenance and take care of the car. If you race around and launch everywhere, you will wear the life for the tcase.
Old Jul 3, 2010 | 12:07 AM
white_evo27's Avatar
Originally Posted by *constant_boost
that.
how many miles should you go before changing tcase/trans fluids?
Old Jul 3, 2010 | 12:14 AM
FQ-300's Avatar
Every 10-15K, depending on driving style. I changed mine at 15K with all Amsoil products and man what a difference. Smooth as silk. I did the complete package:
5: SS0-QT Qts 0W-30
3: MTG-QT Manual Trans Fluid
2: SVG-QT 75W-90 for TC and Diff
Worth every penny
Old Jul 3, 2010 | 12:23 AM
DuderMagee's Avatar
I was told that if you get the T-case shimmed it will greatly lower the possibility of it cracking
I think that shep can do this but IDK for sure
Old Jul 3, 2010 | 11:23 AM
Berts24's Avatar
changing the fluid is pretty key, if you never bring your car to the track but don't change the fluid regularly you can have problems, or if you let the fluid get too low is one. This could happen if you have a bad gasket, there's one guy on here that had a bad gasket at the driveshaft, he wasn't leaking the point where you could see it dripping on the driveway but he ended up ruining the bearing
Old Jul 3, 2010 | 10:53 PM
roadace's Avatar
Agreed.
And it's been said before but change the fluids... 15K or less for me. I'm at 119,xxx miles... no problems.
Old Jul 4, 2010 | 10:56 AM
uvambo's Avatar
When i bought my car (used) dealer said no issues ever with it, but took it in for oil change other day(different dealer) and they said the T/C had been replaced.... pretty pissed with original dealer, but anyway all i know is that you dont want that going out cause the dealer told me it cost them $6000 to replace it
Old Jul 4, 2010 | 12:43 PM
toyotabike's Avatar
Every 15k miles seems really extreme.
Do you guys change the transmission, tranfer c, and rear diff. every 15k
Old Jul 4, 2010 | 09:51 PM
roadace's Avatar
I do... all three components. Mitsubishi recommends 30,000 for normal use and 15,000 for excessive use. When I hit 32,000 miles on the odometer I changed mine for the first time and the car felt dramatically better afterwards. I never went that long again. I'm currently around 14K right now... the next opportunity I have the car on a lift... the fluids are getting changed again.
Old Jul 5, 2010 | 06:06 AM
crazybaldhead's Avatar
You're driving an extreme car.
Old Jul 5, 2010 | 06:52 AM
zshonk23's Avatar
i sent mine to shep trans and mine cost around 1600 to get rebuilt and labor on a tcase would only cost around 300 to 400 if you didnt want to do it yourself
Old Jul 6, 2010 | 07:30 AM
DarksideZ's Avatar
You are correct, he can.
Old Jul 6, 2010 | 07:34 AM
biggieevoIX's Avatar
my transfer case is whining like crazy. the bearing is shot and i am deciding on whether i should get a used tcase off here or send mine into shep trans.
